I have a network dataset that I published so I can use the routing feature for a routing application. The directions widget was running fine but suddenly now it just stays loading after I input the destinations to route. Here is a screenshot of what I mean by 'loading'. Has anyone else had this issue?
Thanks for sending the URL of your route service. The issue with the Directions widget is a known bug and it will be fixed in the April 2018 update of ArcGIS Online (which is scheduled to go live around second week of April 2018)
Thank you, is there any way you could let me know when it gets fixed so I can test it out and see if it works.
On the Web AppBuilder.
Here is the URL:
Route (NAServer)
Cad Assistant 3
This seems like a bug in the directions widget which is caused when it is used with your routing service. In which app are you using the directions widget?
To further troubleshoot, we would need access to the routing service you are using. Is your routing service accessible from the internet? If yes, can you share the URL?
If the service is not available on the internet, can you attach the network dataset (if it s not large). In case, the network dataset is large, send me an email at dmandloi@esri.com and I can provide you with a site where you can safely upload the data.
Deelesh
