I have a federated arcgis server with portal using version 10.7.1 and I am using ArcGIS monitor to connect to the IIS logfiles and I am getting the following error when I test the connection. I have IIS logging every hour.
System.IO.FileNotFoundException: Could not load file or assembly 'SLP.Common, Version=0.9.6.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. at ESRI.PS.EIST.SystemLogParser_Plus.CLI.StartHere.Main(String[] args)
I think it is because it I deed to change the connection string for the token. Any suggestions how to make the connection work?
