import sys, string, os, arcgisscripting gp = arcgisscripting.create() try: gp.CheckOutExtension("spatial") gp.AddToolbox("C:/Arquivos de programas/ArcGIS/ArcToolbox/Toolboxes/Spatial Analyst Tools.tbx") gp.workspace = "E:/GIS_Mestrado/Corumbatai/3_Cartas_um_metro" out_workspace = "E:/GIS_Mestrado/Corumbatai/4_Cartas_Con/" mascara = "E:/GIS_Mestrado/Corumbatai/Geodados/Grid_Cartas_sem_Grade.shp" rasters = gp.ListRasters() raster = rasters.next() while raster: gp.extent = gp.describe(raster).extent gp.snapraster = raster output = out_workspace + raster + ".tif" #reformat as a .tif or whatever - it's that easy! gp.Clip_management(raster, gp.extent, output, mascara, "", "CLIPPINGGEOMETRY") gp.extent = "" #clear the extent raster = rasters.next() except: print "Error in script" print gp.GetMessages()
# Extracts the cells of a raster that correspond with the areas # defined by a mask. # Author: Michel # Date: 10 de Janeiro de 2011 # ----------------------------- # Import system modules import sys, string, os, arcgisscripting # Create the Geoprocessor object gp = arcgisscripting.create() try: # Check out any necessary licenses gp.CheckOutExtension("spatial") # Load required toolboxes... gp.AddToolbox("C:/Arquivos de programas/ArcGIS/ArcToolbox/Toolboxes/Spatial Analyst Tools.tbx") gp.workspace = "E:/GIS_Mestrado/Corumbatai/3_Cartas_um_metro" out_workspace = "E:/GIS_Mestrado/Corumbatai/4_Cartas_Con/" mascara = "E:/GIS_Mestrado/Corumbatai/Geodados/Grid_Cartas_sem_Grade.shp" # Get a list of the rasters in the workspace rasters = gp.ListRasters() # Loop through the list of rasters rasters.reset() raster = rasters.next() while raster: # Set the outputname for each output to be the same as the input output = out_workspace + raster # Process: Extract by Mask... gp.ExtractByMask_sa(raster, mascara, output) # Loop da função... raster = rasters.next() except: # If an error occurred while running a tool, then print the messages. print "Error in script" print gp.GetMessages()
