Hi all,
When I use the 'Raster to ASCII' Conversion tool, my txt or ascii output file is created with comma separators.
I will use the output in another software which only reads files that are point separated.
How can I change the tool set-up (or the ArcGIS set-up) so that the output file created is point separated instead of comma separated?
I have already changed the set-up of my computer in Control Panel so the default is point separated.
Thank you in advance.
