<?xml version="1.0" ?> <!-- File Created with mkPopup.py by Frank Roberts - froberts@innovateteam.com --> <configuration> <!-- Add field name with curly brackets for the title --> <title>Occupant Form</title> <description> <![CDATA[<b>1. When was home built: {UDF9}<br>2. When was last remodeling: {UDF11}<br>3. How long has the tenancy been: {UDF13}<br>4. Do you know property boundaries: {UDF15}<br>5. Boundaries identified by landmarks: {UDF17}<br>6. etc... etc...]]> </description> <fields> <field name="UDF9" /> <field name="UDF11" /> <field name="UDF13" /> <field name="UDF15" /> <field name="UDF17" /> <field name="UDF19" alias="6.Who owns the fence?" /> <field name="UDF21" alias="7.Check box if deed available to be copied" /> <field name="UDF23" alias="8a.Check box if there are deed restrictions" /> <field name="UDF27" alias="9.What underground utilities are there?" /> <field name="UDF29" alias="10.Where are underground sprinklers?" /> <field name="UDF31" alias="11.How are sprinkers turned on/off?" /> <field name="UDF33" alias="12.Utilities shared with adjacent properties?" /> <field name="UDF35" alias="13.Impact on adjacent property if turned off?" /> <field name="UDF37" alias="14.Any underground electrical wiring?" /> <field name="UDF41" alias="16.Check if devices can be turned on/off" /> <field name="UDF43" alias="17.Other environmental issues?" /> <field name="UDF45" alias="18.Where are existing downspouts?" /> <field name="UDF47" alias="19.Are the drains clear?" /> <field name="UDF49" alias="20a.How is the drainage?" /> <field name="UDF51" alias="20b.Are there areas where water puddles?" /> <field name="UDF53" alias="21.Current drainage problems?" /> <field name="UDF55" alias="22a.Check box if there are exterior drains on property" /> <field name="UDF57" alias="22b.Where are exterior drains on property?" /> <field name="UDF59" alias="23.When to schedule remediation?" /> <field name="UDF61" alias="24.Who will inform neighbors?" /> <field name="UDF63" alias="25.Work hours ok with neighbors?" /> <field name="UDF65" alias="26.Check box if neighbor pets on the lot" /> <field name="UDF67" alias="27.Check box if neighbor children on the lot" /> <field name="UDF2" alias="28.Check box if neighbor vehicles near property" /> <field name="UDF4" alias="29.Check box if neighbor willing to move vehicle" /> <field name="UDF6" alias="30.Check box if pets/animals on property" /> <field name="UDF8" alias="31.What kind/ how many pets?" /> <field name="UDF10" alias="32.Check box if pets can be kept indoors" /> <field name="UDF12" alias="33.Check box if pets can be relocated" /> <field name="UDF14" alias="34.Check box if wildlife/strays on lot" /> <field name="UDF16" alias="35.Yard items blocking remediation?" /> <field name="UDF18" alias="36.Check box if ok to use water hose" /> <field name="UDF20" alias="37.Check box if trash to be removed in advance" /> <field name="UDF22" alias="38.Check box if aware of one-time pickup by city" /> <field name="UDF24" alias="39.How to access work site?" /> <field name="UDF26" alias="40.Where to stage work materials?" /> <field name="UDF28" alias="41.Where to place disposal container?" /> <field name="UDF30" alias="42.Obstacles to parking Port-o-let?" /> <field name="UDF32" alias="43.Best place to park Port-o-let?" /> <field name="UDF34" alias="44.Where to park resident vehicles?" /> <field name="UDF36" alias="45.Any signage restrictions?" /> <field name="UDF38" alias="46a.Check box if intend to move plants" /> <field name="UDF40" alias="46b.Which plants to be moved?" /> <field name="UDF42" alias="47.Should we provide buckets?" /> <field name="UDF44" alias="48.Location of immovable structures" /> <field name="UDF46" alias="49.Location of mature trees" /> <field name="UDF48" alias="50.Are you willing to water new sod?" /> <field name="UDF50" alias="51.Any special concerns?" /> <field name="UDF52" alias="Landscaping Selected" /> <field name="UDF54" alias="Check box if resident will help" /> <field name="UDF56" alias="Help Notes" /> <field name="UDF58" alias="Briefing Notes or Why Owner Refused" /> <field name="UDF60" alias="Cleaning Notes" /> <field name="UDF62" alias="Preferred Work Time" /> <field name="UDF64" alias="Comments" /> <field name="UDF66" alias="Sq Ft Running Total" /> <field name="UDF68" alias="Pre-remediation Lead Level (PPM)" /> <field name="UDF69" alias="Project Status" /> </fields> <!-- Show attachments = either true or false --> <showattachments>false</showattachments> </configuration>
<?xml version="1.0" ?> <!-- File Created with mkPopup.py by Frank Roberts - froberts@innovateteam.com --> <configuration> <!-- Add field name with curly brackets for the title --> <title>Occupant Form</title> <fields> <field name="UDF9" alias="1.When was home built" visible="true"/> <field name="UDF11" alias="2.When was last remodeling" visible="true"/> <field name="UDF13" alias="3.How long has the tenancy been?" visible="true"/> <field name="UDF15" alias="4.Do you know property boundaries?" visible="true"/> <field name="UDF17" alias="5.Boundaries identified by landmarks?" visible="true"/> <field name="UDF19" alias="6.Who owns the fence?" visible="true"/> <field name="UDF21" alias="7.Check box if deed available to be copied" visible="true"/> <field name="UDF23" alias="8a.Check box if there are deed restrictions" visible="true"/> <field name="UDF27" alias="9.What underground utilities are there?" visible="true"/> <field name="UDF29" alias="10.Where are underground sprinklers?" visible="true"/> <field name="UDF31" alias="11.How are sprinkers turned on/off?" visible="true"/> <field name="UDF33" alias="12.Utilities shared with adjacent properties?" visible="true"/> <field name="UDF35" alias="13.Impact on adjacent property if turned off?" visible="true"/> <field name="UDF37" alias="14.Any underground electrical wiring?" visible="true"/> <field name="UDF41" alias="16.Check if devices can be turned on/off" visible="true"/> <field name="UDF43" alias="17.Other environmental issues?" visible="true"/> <field name="UDF45" alias="18.Where are existing downspouts?" visible="true"/> <field name="UDF47" alias="19.Are the drains clear?" visible="true"/> <field name="UDF49" alias="20a.How is the drainage?" visible="true"/> <field name="UDF51" alias="20b.Are there areas where water puddles?" visible="true"/> <field name="UDF53" alias="21.Current drainage problems?" visible="true"/> <field name="UDF55" alias="22a.Check box if there are exterior drains on property" visible="true"/> <field name="UDF57" alias="22b.Where are exterior drains on property?" visible="true"/> <field name="UDF59" alias="23.When to schedule remediation?" visible="true"/> <field name="UDF61" alias="24.Who will inform neighbors?" visible="true"/> <field name="UDF63" alias="25.Work hours ok with neighbors?" visible="true"/> <field name="UDF65" alias="26.Check box if neighbor pets on the lot" visible="true"/> <field name="UDF67" alias="27.Check box if neighbor children on the lot" visible="true"/> <field name="UDF2" alias="28.Check box if neighbor vehicles near property" visible="true"/> <field name="UDF4" alias="29.Check box if neighbor willing to move vehicle" visible="true"/> <field name="UDF6" alias="30.Check box if pets/animals on property" visible="true"/> <field name="UDF8" alias="31.What kind/ how many pets?" visible="true"/> <field name="UDF10" alias="32.Check box if pets can be kept indoors" visible="true"/> <field name="UDF12" alias="33.Check box if pets can be relocated" visible="true"/> <field name="UDF14" alias="34.Check box if wildlife/strays on lot" visible="true"/> <field name="UDF16" alias="35.Yard items blocking remediation?" visible="true"/> <field name="UDF18" alias="36.Check box if ok to use water hose" visible="true"/> <field name="UDF20" alias="37.Check box if trash to be removed in advance" visible="true"/> <field name="UDF22" alias="38.Check box if aware of one-time pickup by city" visible="true"/> <field name="UDF24" alias="39.How to access work site?" visible="true"/> <field name="UDF26" alias="40.Where to stage work materials?" visible="true"/> <field name="UDF28" alias="41.Where to place disposal container?" visible="true"/> <field name="UDF30" alias="42.Obstacles to parking Port-o-let?" visible="true"/> <field name="UDF32" alias="43.Best place to park Port-o-let?" visible="true"/> <field name="UDF34" alias="44.Where to park resident vehicles?" visible="true"/> <field name="UDF36" alias="45.Any signage restrictions?" visible="true"/> <field name="UDF38" alias="46a.Check box if intend to move plants" visible="true"/> <field name="UDF40" alias="46b.Which plants to be moved?" visible="true"/> <field name="UDF42" alias="47.Should we provide buckets?" visible="true"/> <field name="UDF44" alias="48.Location of immovable structures" visible="true"/> <field name="UDF46" alias="49.Location of mature trees" visible="true"/> <field name="UDF48" alias="50.Are you willing to water new sod?" visible="true"/> <field name="UDF50" alias="51.Any special concerns?" visible="true"/> <field name="UDF52" alias="Landscaping Selected" visible="true"/> <field name="UDF54" alias="Check box if resident will help" visible="true"/> <field name="UDF56" alias="Help Notes" visible="true"/> <field name="UDF58" alias="Briefing Notes or Why Owner Refused" visible="true"/> <field name="UDF60" alias="Cleaning Notes" visible="true"/> <field name="UDF62" alias="Preferred Work Time" visible="true"/> <field name="UDF64" alias="Comments" visible="true"/> <field name="UDF66" alias="Sq Ft Running Total" visible="true"/> <field name="UDF68" alias="Pre-remediation Lead Level (PPM)" visible="true"/> <field name="UDF69" alias="Project Status" visible="true"/> </fields> <!-- Show attachments = either true or false --> <showattachments>false</showattachments> </configuration>
