I am trying to replace a <Null> value in a selected field. When I do a find and replace I get an error that no fields have been detected. I have put in to find <Null> and replace it with the info that I want. I have selected the field but I still get this error. Can anyone help me with this? Is there a better or another way to do this? It just takes too long to select each field and type in the replacement info.
import arcpy import os # replace data path with your OWN data. in_data = r"C:\Data\Sample.mdb\NullValues" field_list = [] numeric_fields = ["Double", "Integer", "SmallInteger"] fields = arcpy.ListFields(in_data) for field in fields: if (field.type in numeric_fields): field_list.append(field.name) # convert the list of fields to a semicolor delimited string fields = ";".join(field_list) rows = arcpy.UpdateCursor(in_data, '', '', fields) count = len(field_list) for row in rows: for k in range(count): if row.isNull(field_list): row.setValue(field_list, 0) rows.updateRow(row)
If IsNull() Then ' Substitute with your real field name here Output = 0 ' Specify the replacement value for Null here. Make sure it is valid for the field you are calculating. Else Output = ' Substitute with your real field name here End If
