Hi Mark,
Thank you, that all makes a lot of sense, understanding that AdjointCatchments are "pre-delineated" watersheds has cleared up a lot. I have a few more questions if you don't mind.
1. Is there anyway to automate the delineation of watersheds, without going in and setting individual points? And is this possible for sub-watershed delineation as well? I am working in an area that does not have gage stations, which is the example that is used for watershed delineation in most of the tutorials I have read.
Additionally, the subwatersheds are going to be used as the boundaries for local area environmental plans. It would be ideal if these could be of similar sizes to aid in the planning process. Since there is some flexibility in size of subwatershed, depending on where I place the point, some mechanism to outline the general size in an automation process would be great, although maybe I'm hoping for two much!
2. I am working in an area with a lot of coastline. I would like the watersheds to extend all the way to the coast to cover the entire study area. By experimenting I found that the smaller the threshold used when defining streams the more catchments that are generated, with many of them coming to the coast, leaving just a few gaps. Is there a better way to force delineation along a coastline or am I doing the correct thing?
3. Since I have defined streams/drainage lines quite small in order to get them all the way to the coast you can see that there are many small streams flowing into the ocean (see image). Technically, each one of these is their own watershed if I were to delineate them. However this seems odd to me, do you know what is generally done in this situation? I hope that question makes sense.
Thank you!
Esther,
Welcome to Arc Hydro!
Catchments are Arc Hydro's basic watershed delineation of the agreedem based on the strlnk raster. A Catchment polygon is created for each confluence of the DrainageLines (or for each DrainagePoint). The number or density of the DrainageLines is based on the number of cells you chose in the stream definition step. The fewer the number of cells, the more "dense" the DrainageLine features (these come from the strlnk raster) and smaller the Catchment polygons.
After the Catchments are created, the AdjointCatchments are created. Each successive AdjointCatchment polygon consists of the next downstream Catchment. So the AdjointCatchment polygons overlap where as the Catchment polygons do not.
The purpose of the AdjointCatchment polygons is to make delineation of the watersheds and subwatersheds fast; very fast compared to delineating them without the adjoint catchments. Basically, the AdjointCatchment polygons are "pre-delineated" watersheds that make future delineations relatively quick compared to how the were originally done.
The DrainagePoints, DrainageLines, Catchments and AdjointCatchment (I think that's all) are part of a geodatabase network that Arc Hydro builds. If you study the DrainID and HydroID fields of the various vector feature classes you will see that there is a relationship there that associates them. These are used for the network. With this network, Arc Hydro can delineate a watershed quickly. When you process a watershed or subwatershed at point using Arc Hydro Watershed Processing tools, the area upstream of the point is "chosen" using the upstream AdjointCatchment polygon and then Arc Hydro only has to do the "tedious delineating" of the agreedem for a small part of the dem that is downstream of the AdjointCatchment polygon. This "tediously delineated" area and the AdjointCatchment area are combined to make a Watershed for the point that was processed.
As the story goes, when the Arc Hydro team demonstrated the use of a network in watershed delineation at a conference, the conferees thought it was a trick because it was so fast. Before that, the delineations took a laborious amount of time. At least that's what I heard from ESRI during training.
Of course, you can use the Catchment and AdjointCatchment polygons for other purposes.
Best,
Mark
Hi Malcolm,
I am wondering what your final solution was. Did you end up doing what you've outlined in the above comment? I have the exact same assignment and was also stuck on the functional difference between catchments and watersheds. It appears that adjointcatchments are the largest drainage basins in my study area, thereby acting as the largest possible watersheds, and the catchments within the adjointcatchments would be subwatersheds. This is my first time using archydro though so any guidance is much appreciated.
Thanks!
I think in general they are synonymous. Watershed, catchment, basin... these terms all mean the same thing, really (to me). They are confusing because these words or parts of them are sometimes used for other drainage related things: catchbasin, detention basin, watershed (as the ridge line or watershed divide), etc. ... I'm sure I'm missing others and some people may disagree with my definition of these terms since their "culture" used them differently than mine.
In Arc Hydro, "Catchment" is the default name used for the the "watershed" polygons that correspond to the stream link (strlnk) grid. These do not overlap each other.
In Arc Hydro, "AdjointCatchment" is the default name used for the the "watershed" polygons that correspond to the stream link (strlnk) grid. These overlap each other. They are used as part of the geo-network to make delineation of the watersheds very fast, the whole reason behind the DrainagePoint, DrainageLine, AdjointCatchments layers and HydroIDs, NextDownIDs, DrainageIDs in the first place.
In Arc Hydro, "Watershed" is the default name used for the the "watershed" polygons that correspond to the BatchPoint points. These overlap each other. That is, the Watershed polygons include all areas that drain to the point per the flow direction grid.
In Arc Hydro "Subwatershed" is the default name used for the the "watershed" polygons that correspond to the BatchPoint points. These do not overlap each other. That is, the Subwatershed polygons include only the areas that drain to the BatchPoint per the flow direction grid below any upstream batch points.
If you don't like the default names, you can always change them. I used to until I got tired of doing that. Eventually, I just embraced them.
Of course, this is just my understanding. You may find better information elsewhere.
