this.addEventListener(GraphicEvent.GRAPHIC_ADD, onGraphicAdd); this.addEventListener(GraphicEvent.GRAPHIC_REMOVE, onGraphicRemove); this.addEventListener(GraphicsLayerEvent.GRAPHICS_CLEAR, onGraphicsClear);
package org.lacsd.layers { import com.esri.ags.Graphic; import com.esri.ags.events.GraphicEvent; import com.esri.ags.events.GraphicsLayerEvent; import com.esri.ags.layers.FeatureLayer; import flash.events.MouseEvent; import mx.utils.ObjectUtil; public class TestFeatureLayer extends FeatureLayer { public function TestFeatureLayer(url:String=null, proxyURL:String=null, token:String=null) { super(url, proxyURL, token); this.addEventListener(GraphicEvent.GRAPHIC_ADD, onGraphicAdd); this.addEventListener(GraphicEvent.GRAPHIC_REMOVE, onGraphicRemove); this.addEventListener(GraphicsLayerEvent.GRAPHICS_CLEAR, onGraphicsClear); } private function addListener(graphic:Graphic):void { graphic.addEventListener(MouseEvent.MOUSE_OVER, function(event:MouseEvent):void { graphic.useHandCursor = true; graphic.buttonMode = true; map.openHandCursorVisible = false; trace("mouse over"); }); graphic.addEventListener(MouseEvent.MOUSE_OUT, function(event:MouseEvent):void { graphic.useHandCursor = false; graphic.buttonMode = false; map.openHandCursorVisible = true; trace("mouse out"); }); graphic.addEventListener(MouseEvent.CLICK, function(event:MouseEvent):void { trace("Click"); }) } private function onGraphicAdd(event:GraphicEvent):void { trace("graphic has been added", ObjectUtil.toString(event.graphic.attributes)); this.addListener(event.graphic); // add listeners here } private function onGraphicRemove(event:GraphicEvent):void { trace("graphic has been removed", ObjectUtil.toString(event.graphic.attributes)); // remove listeners here } private function onGraphicsClear(event:GraphicsLayerEvent):void { // may want to find a way to remove listeners here or add them with a weak reference } } }
public class BuildingFeatureLayer extends FeatureLayer { private var defaultSymbol:SimpleFillSymbol = new SimpleFillSymbol(); private var mouseOverSymbol:SimpleFillSymbol = new SimpleFillSymbol(); public function BuildingFeatureLayer() { super(); setLoaded(true); defaultSymbol.color = 0xFFFFFF; defaultSymbol.alpha = 0.1; mouseOverSymbol.color = 0xFF0000; mouseOverSymbol.alpha = 0.5; this.mode = "snapshot"; this.symbol=defaultSymbol; this.outFields = []; this.url="http://<server>/ArcGIS/rest/services/layers/<layername>/MapServer/0" this.useAMF=false; this.visible=true; } override protected function updateLayer():void { super.updateLayer(); } // OVERRIDING THIS METHOD IS NOT PERMITTED BY THE API override public function add(graphic:Graphic):void { graphic.toolTip = graphic.attributes.BUILDING_NAME; graphic.addEventListener( MouseEvent.ROLL_OVER, graphic_mouseOverHandler ); graphic.addEventListener( MouseEvent.ROLL_OUT, graphic_mouseOutHandler ); }
queryTask.execute(query, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { for each (var graphic:Graphic in featureSet.features) { graphic.addEventListener(MouseEvent.MOUSE_OVER, function(event:MouseEvent):void { graphic.useHandCursor = true; graphic.buttonMode = true; map.openHandCursorVisible = false; trace("mouse over"); }); graphic.addEventListener(MouseEvent.MOUSE_OUT, function(event:MouseEvent):void { graphic.useHandCursor = false; graphic.buttonMode = false; map.openHandCursorVisible = true; trace("mouse out"); }); graphic.addEventListener(MouseEvent.CLICK, function(event:MouseEvent):void { trace("Click"); }) } }
