Hi Matt,My desired naming convention per model will be similar to:CitI0005.daeThis model name is taken from the shape's object attributes and exported per-inital shape using the following script: from scripting import * ce = CE() def export(object, modelName): dir = ce.toFSPath("models/") settings = DAEExportModelSettings() settings.setGeneralLocation(dir) settings.setGeneralName(modelName) settings.setGranularityFile(DAEExportModelSettings.PER_INITIAL_SHAPE) settings.setMiscOptionsWriteExportLog(False) ce.export(object, settings) if __name__ == '__main__': print ("__DAE Export Loop Started__") shapes = ce.getObjectsFrom(ce.selection, ce.isShape) IDshape = 0 for shape in shapes : name = ce.getAttribute(shape, 'MODEL') string = name.rstrip('3ds') modelName = string.strip('.') export(shape, modelName) print(modelName) IDshape += 1 pass print ("__All Selected Models Exported__") This exports each model with a name such as:CitI0005_shape99.daeTo strip the shape name from each file I just run the following script externally: # Modules import os, shutil # Root folder for files daeRoot = r'C:\Users\******\Desktop\Sort' def renameFiles(target): os.chdir(target) for filename in os.listdir('.'): print filename fullname = os.path.splitext(filename)[0] ext = os.path.splitext(filename)[1] prefix = fullname [:8] newfilename = prefix + ext print newfilename os.rename(filename, newfilename) print "Renamed " + filename + " to " + newfilename if (__name__ == '__main__'): renameFiles(daeRoot) I was just wondering if there was a way to export without the shape name so I don't have to run this extra script to strip the characters? 🙂
