Hi Scott,the code is in 1750. Typically COM1 and COM3 are system reserved ports and therefore the code checks to see if there are more ports than simply these two as it omits them from being used. If these are the only two COM ports it sees, you get the message that you've been experiencing.You can reset the COM port number to something else. Once you do, you will be able to make a connection. Other occurrences of this are with Garmin devices as they typically do not create a virtual port for use. Garmin has a app call Spanner that creates a virtual port for the device to be read from and so allows for normal connectivity.Let me know how you get on?Edan
