I think we may be talking about different "templates" here...Here's what you can do from arcgis.com.You can author a web map and share it with a group.You can download a web application template from the Share button on the Map Viewer.You can 'Publish' that application to arcgis online if you don't have a web server, or you can 'Download' it to deploy to your own server. The advantage of downloading is that you have the source code and can modify the application. However, some of these template are configurable without programming.Because your map is not shared with everyone, any user who is a member of the group it is shared with can sign in with their Esri Global ID and access the application.The attached image shows where in the Map Viewer you'll find these template applications.Thanks,Mike
I think this is a proxy issue. The proxy would need to be on the applications web server. The proxy url is set in index.html, look for the proxyurl option. The proxy isn't always used - but there are some situations when its needed. Another issue you might run into is that the identity manager expects the app to be running using https since you are working with secure items. If its not run over https then you might see the log-in dialog appear but it won't successfully log you in. If you are working with only public web maps and services then the templates should work - its only going to be an issue when you are working with non-public maps.
you can also install cartoview www.cartologic.com/cartoview and define simple arcgis services which you can use directly in your web application
