#Chris Snyder, WADNR, 20120126 import arcpy, math, random containerFC = r"C:\csny490\test.shp" outputFC = r"C:\csny490\out.shp" spacing = 100 useRandomShift = True arcpy.env.overwriteOutput = True dsc = arcpy.Describe(containerFC) dscExtent = dsc.extent xMin = dscExtent.xMin yMin = dscExtent.yMin xMax = dscExtent.xMax yMax = dscExtent.yMax randomXshift = random.uniform(0, spacing) randomYshift = random.uniform(0, spacing) yOffset = math.sqrt((spacing **2) - ((spacing / 2) **2)) pntDict = {} i = 0 rowNumber = 1 xCoord = xMin - spacing yCoord = yMin - spacing while xCoord < xMax + spacing or yCoord < yMax + spacing: i = i + 1 if xCoord > xMax + spacing: rowNumber = rowNumber + 1 xCoord = xMin - spacing if bool(rowNumber & 1) == False: xCoord = xCoord + spacing / 2 yCoord = yCoord + yOffset elif i == 1: xCoord = xCoord else: xCoord = xCoord + spacing if useRandomShift == True: pntDict = (xCoord + randomXshift, yCoord + randomYshift) else: pntDict = (xCoord, yCoord) arcpy.CreateFeatureclass_management(outputFC[:-len(outputFC.split("\\")[-1]) - 1], outputFC.split("\\")[-1], "POINT", "", "", "", dsc.spatialreference, "", "", "", "") shapeFieldName = arcpy.Describe(outputFC).shapeFieldName insertRows = arcpy.InsertCursor(outputFC) for pnt in pntDict: insertRow = insertRows.newRow() pointObj = arcpy.CreateObject("Point") pointObj.X = pntDict[pnt][0] pointObj.Y = pntDict[pnt][1] insertRow.setValue(shapeFieldName, pointObj) insertRows.insertRow(insertRow) del pointObj, insertRow, insertRows
Question: Do you want the points like this #aligned like a square (not equadistant) + + + + + + + + + + + + + + + + or like this:#aligned like a tringle/diamond (equadistant) + + + + + + + + + + + + + + + +If it's the former, just use the fishnet tool (and convert the polygon centroids to points using the FeatureToPoint tool), or as Darren suggests, use a raster/vector hybrid approach If it's the latter (which is what we use BTW to lay out our inventory plots), I think I have some code that I can borrow from someone. Let me know, and I'll try to post it (if they let me).
