import arcpy, os # access your table(s) intbl = r'C:\path\to\your\FileGeodatabase.gdb\inputtable' outtbl = r'C:\path\to\your\FileGeodatabase.gdb\outputtable' # optionally create output table, using the input table as schema # CreateTable_management (out_path, out_name, {template}, {config_keyword}) outpath, outname = os.path.split(outtbl) arcpy.CreateTable_management(outpath, outname, intbl) # have a close look at the fieldnames, some names may be restricted # and are changed by ArcGIS when imported from for instance Excel flds = ['number','Code','Year'] # do a search cursor on the input table and an insert cursor on the output table outcurs = arcpy.da.InsertCursor(outtbl, flds) with arcpy.da.SearchCursor(intbl, flds) as incurs: for row in incurs: numbers = row[0].split(',') for number in numbers: # for each 'number' a record is written outcurs.insertRow((number.strip(), row[1], row[2])) del outcurs
Hello!I am working with a table and I would like to get this:number(stored as text) Code Year0500, 0600, 0700 ABC1 2012to this:number Code Year0500 ABC1 20120600 ABC1 2012 0700 ABC1 2012I have gotten to where I can insert each number/space/comma into a new row but obviously I need it to break it at the commas. Ideas?
import arcpy import pandas as pd import numpy as np input_table = r'H:\Documents\ArcGIS\Default.gdb\fliptab' ##convert the input_table into a numpy array nparr = arcpy.da.TableToNumPyArray(input_table, ['number', 'code', 'year']) ##convert the array into a pandas data frame df = pd.DataFrame(nparr.tolist(), columns=['number', 'code', 'year']) ##deconstruct the column containing the commas and transpose into rows s = df['number'].apply(lambda x: pd.Series(x.split(','))).stack() s.index = s.index.droplevel(-1) s.name = 'number' ##join the original dataframe and the temp series del df['number'] outdf = df.join(s) ##convert the df into a numpy array out_nparr = np.array(outdf.to_records(), np.dtype([('code', '|S10'), ('year', np.int32), ('number', '|S10')])) outTable = r'H:\Documents\ArcGIS\Default.gdb\fliptab_output' ##finally covert the numpy array back into the gdb table arcpy.da.NumPyArrayToTable(out_nparr, outTable, ("code", "year", "number"))
import arcpy, numpy intbl = r'C:\Project\_Forums\CommaDelimitField\test.gdb\intable' outtbl = r'C:\Project\_Forums\CommaDelimitField\test.gdb\tst01' flds = ('number_','Code','Year_') # list comprehensions lst_in = [row for row in arcpy.da.SearchCursor(intbl, flds)] lst_out = [(num, row[1], row[2]) for row in lst_in for num in row[0].split(', ')] # use numpy to store the table npa = numpy.array(lst_out, numpy.dtype([('number', '|S10'), ('code', '|S10'), ('year', numpy.int32)])) arcpy.da.NumPyArrayToTable(npa, outtbl, ("number", "code", "year"))
Hi Amy,I think this will do the job:
While we're at it, using part of the idea James suggested (the numpy part) and mixing it with some list comprehensions I came up with this:import arcpy, numpy intbl = r'C:\Project\_Forums\CommaDelimitField\test.gdb\intable' outtbl = r'C:\Project\_Forums\CommaDelimitField\test.gdb\tst01' flds = ('number_','Code','Year_') # list comprehensions lst_in = [row for row in arcpy.da.SearchCursor(intbl, flds)] lst_out = [(num, row[1], row[2]) for row in lst_in for num in row[0].split(', ')] # use numpy to store the table npa = numpy.array(lst_out, numpy.dtype([('number', '|S10'), ('code', '|S10'), ('year', numpy.int32)])) arcpy.da.NumPyArrayToTable(npa, outtbl, ("number", "code", "year")) Kind regards,Xander
Nice! I pulled from one of our impmentations with lots of pandas DataFrame processing, but I like this suggestion for just numpy work.
Hi James, it's posts like yours (thinking outside the box) that lets me learn something new every day... (+1 for that).Kind regards,Xander
