//identify features private function identifyFeatures():void { var identifyParams : IdentifyParameters = new IdentifyParameters(); identifyParams.returnGeometry = false; identifyParams.tolerance = identifyTolerance; identifyParams.geometry = identifyPoint; identifyParams.width = map.width; identifyParams.height = map.height; identifyParams.mapExtent = map.extent; identifyParams.spatialReference = map.spatialReference; for (var i:Number = map.layerIds.length -1; i >= 0; i--) { identifyParams.layerOption = identifyLayerOption; identifyParams.layerIds = null var layer:Layer = map.getLayer(map.layerIds); var url:String; if (layer.visible) { if (layer is ArcGISDynamicMapServiceLayer) { var dynamicLayer:ArcGISDynamicMapServiceLayer = layer as ArcGISDynamicMapServiceLayer; url = dynamicLayer.url; if(identifyLayerOption == "visible") { identifyParams.layerIds = dynamicLayer.visibleLayers.source; identifyParams.layerOption = "all"; if(dynamicLayer.visible == false) url=""; } //This is the new code //Change Parcel Data to the map service name of yours you want to use //and change 67,68 to the layer numbers of yours //in the else url=""; is what makes it ignore all other map services //if there name is not (in my example) Parcel Data. if (layer.id == "Parcel Data") { identifyParams.layerIds = [67,68]; } else { identifyParams.layerIds = null; url=""; } } else if (layer is ArcGISTiledMapServiceLayer) { var tiledLayer:ArcGISTiledMapServiceLayer = layer as ArcGISTiledMapServiceLayer; url = tiledLayer.url; if(identifyLayerOption == "visible") { if(tiledLayer.visible == false) url=""; } } if(url) { var identifyTask:IdentifyTask = new IdentifyTask(url); identifyTask.addEventListener(IdentifyEvent.IDENTIFY_COMPLETE, onResult); identifyTask.addEventListener(FaultEvent.FAULT, onFault); identifyTask.execute(identifyParams); showMessage(loadingLabel, true); showStateResults(null); } } } }
