java.lang.IllegalArgumentException: URI is not hierarchical at java.io.File.<init>(File.java:392) at com.esri.arcgis.interop.NativeLoader.getArcGISHome(Unknown Source) at com.esri.arcgis.interop.NativeLoader.loadLibrary(Unknown Source) at com.esri.arcgis.system.EngineInitializer.initializeEngine(Unknown Source) at SdeOrPgdb.main(SdeOrPgdb.java:70) at BrowsePath.actionPerformed(BrowsePath.java:317) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6505) at javax.swing.JComponent.processMouseEvent(JComponent.java:3321) at java.awt.Component.processEvent(Component.java:6270) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4861) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735) at java.awt.EventQueue.access$200(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:694) at java.awt.EventQueue$3.run(EventQueue.java:692) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:708) at java.awt.EventQueue$4.run(EventQueue.java:706) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:705) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) Error: null Sample failed. Exiting... java.lang.NullPointerException at com.esri.arcgis.interop.NativeLoader.getArcGISHome(Unknown Source) at com.esri.arcgis.interop.NativeLoader.loadLibrary(Unknown Source) at com.esri.arcgis.system.EngineInitializer.initializeEngine(Unknown Source) at SdeOrPgdb.main(SdeOrPgdb.java:70) at BrowsePath.actionPerformed(BrowsePath.java:317) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6505) at javax.swing.JComponent.processMouseEvent(JComponent.java:3321) at java.awt.Component.processEvent(Component.java:6270) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4861) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735) at java.awt.EventQueue.access$200(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:694) at java.awt.EventQueue$3.run(EventQueue.java:692) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:708) at java.awt.EventQueue$4.run(EventQueue.java:706) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:705) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
//Replace the following line with the name of your main application. // App.main(args); Globe3DEventBug.main(args);
public class Console { public static void main(String[] args) { System.setSecurityManager(null); try{ //Step 1: Initialize the Java Componet Object Model (COM) Interop. EngineInitializer.initializeEngine(); //Step 2: Initialize an ArcGIS license. AoInitialize aoInit = new AoInitialize(); initializeArcGISLicenses(aoInit); //Step 3: Invoke ArcObjects. Do ArcObjects stuff here... //Step 4: Release the license. aoInit.shutdown(); EngineInitializer.releaseAll(); } catch (IOException ex){ System.out.println(ex.getMessage()); System.out.println("App failed."); } } static void initializeArcGISLicenses(AoInitialize aoInit){ try{ if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeArcInfo) == esriLicenseStatus.esriLicenseAvailable){ aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeArcInfo); } else{ System.err.println("ArcInfo license not initialized."); System.err.println("Exiting application."); System.exit( - 1); } } catch (Exception e){ e.printStackTrace(); } } }
public class SdeOrPgdb { public SdeOrPgdb(){ } public static void main(String[] args) { try{ bootstrapArcobjectsJar(); //Initialize engine console application EngineInitializer.initializeEngine(); //Initialize ArcGIS license AoInitialize aoInit = new AoInitialize(); initializeArcGISLicenses(aoInit); SdeOrPgdb accessFileGDB = new SdeOrPgdb(); accessFileGDB.openFromFile_sde_Workspace(); System.out.println("Done."); //Ensure any ESRI libraries are unloaded in the correct order aoInit.shutdown(); }catch(Exception e){ System.out.println("Error: " + e.getMessage()); System.out.println("Sample failed. Exiting..."); e.printStackTrace(); System.exit(-1); } } private static void initializeArcGISLicenses(AoInitialize aoInit) { try { if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeEngine) == esriLicenseStatus.esriLicenseAvailable) aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeEngine); else if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeArcView) == esriLicenseStatus.esriLicenseAvailable) aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeArcView); else{ System.err.println("Could not initialize an Engine or ArcView license. Exiting application."); System.exit(-1); } } catch (Exception e) {e.printStackTrace();} } public static void bootstrapArcobjectsJar(){ //Get the ArcGIS Engine runtime, if it is available String arcObjectsHome = System.getenv("AGSENGINEJAVA"); //If no runtime is available, exit application gracefully if (arcObjectsHome == null){ System.err.println( "You must have the ArcGIS Engine Runtime installed in order to execute this application."); System.err.println( "Install the product above, then re-run this application."); System.err.println("Exiting execution of this application..."); System.exit( - 1); } //Obtain the relative path to the arcobjects.jar file String jarPath = arcObjectsHome + "java" + File.separator + "lib" + File.separator + "arcobjects.jar"; //Create a new file File jarFile = new File(jarPath); //Test for file existence if (!jarFile.exists()){ System.err.println( "The arcobjects.jar was not found in the following location: " + jarFile.getParent()); System.err.println( "Verify that arcobjects.jar can be located in the specified folder.") ; System.err.println( "If not present, try uninstalling your ArcGIS software and reinstalling it."); System.err.println("Exiting execution of this application..."); System.exit( - 1); } //Helps load classes and resources from a search path of URLs URLClassLoader sysloader = (URLClassLoader)ClassLoader.getSystemClassLoader() ; Class < URLClassLoader > sysclass = URLClassLoader.class; try{ Method method = sysclass.getDeclaredMethod("addURL", new Class[]{ URL.class } ); method.setAccessible(true); method.invoke(sysloader, new Object[]{ jarFile.toURI().toURL() } ); } catch (Throwable throwable){ throwable.printStackTrace(); System.err.println("Could not add arcobjects.jar to system classloader"); System.err.println("Exiting execution of this application..."); System.exit( - 1); } }
