PS: Not sure why code indentation is getting messed up when I paste it here...
# untested, probably needs a bit of debugging, and typo fixing CONTOUR_CLASSES = ((20, '5m Contour'), (4, '1m Contour'), # Do you really want the next class? Remove to group with 0.25m contours (3, '0.75m Contour'), (2, '0.5m Contour'), (1, '0.25m Contour')) def classify_contour_value(elevation): for cc, cc_desc in CONTOUR_CLASSES: if int(elevation * 4) % cc == 0: # if dividable by cc it belongs to that class return cc_desc
fc = r"D:/LIDAR/Lidar.gdb/Contour_pt25m" # Creates the cursor rows = gp.UpdateCursor(fc) # Looping gets so much simpler if you let python do the work for you: for row in iter(rows.Next, None): # Convert the geoprocessing iterator to a python iterator con_value = row.CONTOUR # shouldn't be named 'txt' if is a floating point value... con_txt = classify_contour_value(con_value): row.Layer = con_txt rows.UpdateRow(row) # row = rows.Next() # So easy to forget this line and you get an infinite loop. # with a for-loop instead you transfer the resposiblity for this call to the python internals # Clean up cursors ##del rows ##del row # Since the python del statement doesn't delete anything, I prefer setting values to None, but # that is mostly a matter of taste: row = None rows = None
My question is:Is this the cleanest way around this problem? Or is there some other python function I should use?
