Thanks for the help Nancy.I managed to import the schema to the GDB OK, but now when i try to import the S-57 cell, the option is greyed-out. Any ideas?
I'm trying to import S-57 files into a geodatabase using the S-57 to Geodatabase tool.Within ArcMap, I create a new file GDB and then create a Feature Dataset. I then right click on the feature dataset and select Import > S-57 to Geodatabase and I get the following error:"There was a problem loading the product configuration file"Where do I set this configuration file and what is the likely problem?I'm new to the Nautical Solution, and it seems like a steep learning curve. Any help would be appreciated, thanks.
Karl,Make sure that the Production Mapping and Nautical extensions are turned on. To do this you simply go to Customize on the Standard toolbar, click on extensions, and make sure that both the Production Mapping and Nautical extensions are turned on.If this doesn't do the trick, let me know and we'll trouble shoot further, K? 😉Nancy
I'm also having an issue with trying to export the Geodatabase to S-57. I have to run Update Primitives first but that option is greyed out on the Production Editing toolbar. The Production Mapping and Nautical extensions are turned on.
I'm also a little confused with the concept of product geodatabases and product instances. From the Help documentation I am under the impression that product instances can only be created on "personal ArcSDE" databases (i.e. Microsoft SQL Server Express). However in the tutorial examples they are stored in File GDBs.
Make sure that you are in an edit session to run Update Primitives...you must start an edit session to run the tool.
---------------------------------- Export report for cell US4LA30M ---------------------------------- Error while initializing FREL Cache.-2147220985 ExportEN failed-2147220985 Total export time: 0 Hrs 0 Mins 8 Secs
