Grief...now why would they do that, without giving the option to the user to omit the scaling
The values should be >-0.1 (convex), -0.1 to -0.4 (planar), and >-o.4 (concave). My values are much larger as shown in an attachment.
Curvature values are artificially multiplied by 100, Stan: http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=How%20Curvature%20works .
StanIf the coordinates are in decimal degrees, the elevation will not be (doesn't make sense, elevation is either in meters or feet). This is what I was questioning. since you indicate that the coordinates are in decimal degrees, the file(s) should be projected so that the coordinates ( X and Y) are in the same units as elevation ( Z ) whether it be meters or feet. Bill indicated that the software (arbitrarily??) multiplies the resultant by 100, essentially expressing values as a percentage. Try projecting the data to a suitable projection, redo the analysis and see if the resultant makes more sense (accounting for the scaling)
Yes, but not a billion!
