Option Explicit Dim varUniqueID Sub UniqueID ' CREATE THE VARAIBLE AND ASSIGN IT THE CREATED GUID ' Dim createUniqueID ' I commented this varaible out because I delclared it global above in the option explicit...you can delete the global varaible and declare it here if you want... ' globally you can do other stuff with it... varUniqueID= System.CreateGuid ' NEXT YOU HAVE TO GRAB THE FORM PAGE AND ASSIGN THE VARAIBLE TO THE TEXTBOX Dim objRS, objSelLayer, objEFPageOneControls3, objEditForm3 Set objSelLayer = Map.SelectionLayer Set objRS = objSelLayer.Records objRS.Bookmark = Map.SelectionBookmark Set objEditForm3 = application.map.layers("Outfalls").forms("EDITFORM") Set objEFPageOneControls3 = objEditForm3.Pages("page1").Controls objEFPageOneControls3("Edit1").Value = varUniqueID End Sub
We simply created a field for out unique ID and enter it manually. So if I was entering the unique ID at the time of this writing, I would simply enter 1107271120 for 11-year, 07-Month, 27-day, 1120- hour. It requires typing with each feature created, but it is simple.
Rolf, I'm a bit of a novice with ArcPad. Would I do this script in ArcStudio in the axf file on the desk top, create a new field for the unique ID and then load it into the Trimble unit? Thanks for any additional guidance on how to do this.
