Have attributes from 1 point that display on map. Can't select it.
Try and select it. Most likely it is a text element on the layout.
Yeah, I never put the 2 together… But working through everbody’s suggestions got me there!!
Thanks for the help!
The missing bits... SDE and edit mode ...
Actually it just got fixed it… It has not been selectable, but I tried one more time and it let me delete it!
I realize that I was trying to select it in editor mode. However the Item was not in the the SDE I was editing!
Duh....
Thanks for suggestions!
Every suggestion is a learning experience!
ArcMap 10.2.1
dataframe/map & Layout view
Will have to check on the copy part.
ArcMap? ArcGIS PRO? version?
Is the dataframe/map view?
layout?
you are sure they aren't graphics?
What if you open a new dataframe/map view and copy the files to there, one at a time... checking as you go... does it still persist?
Yes sir, I did.
That’s the first thing I thought.
Software?
It looks like a ghost of an attribute table. Did you try a save and reboot, and reload?
