1>>> SubjectLyr = arcpy.mapping.Layer("Y:\\Notification Radius Pkgs\\Dave3\\Shapefiles\\Dave3Subject.shp") # use either \\ or / in paths 2>>> mxd = arcpy.mapping.MapDocument("CURRENT") 3>>> df = arcpy.mapping.ListDataFrames(mxd, "Radius Map")[0] 4>>> wPath = "Y:\\Notification Radius Pkgs\\" # same as in line 1 5>>> arcpy.mapping.AddLayer(df, SubjectLyr,"AUTO_ARRANGE") 6>>> SubjectLyr = arcpy.mapping.ListLayers(mxd, SubjectLyr.name, df)[0] # change reference to layer in mxd 7>>> sourceLayer = arcpy.mapping.Layer(wPath+"Setup10\\LayerFiles\\Subject.lyr") # same as in line 1 8>>> arcpy.mapping.UpdateLayer(df, SubjectLyr, sourceLayer, True)
SubjectLyr = arcpy.mapping.Layer(r"F:\\testFiles\\output\\Population23_KDens.lyr") mxd = arcpy.mapping.MapDocument("F:\\testFiles\\testMap.mxd") df = arcpy.mapping.ListDataFrames(mxd)[0] wPath = "F:\\testFiles\\output\\" # same as in line 1 #Add the layer to basemap arcpy.mapping.AddLayer(df, SubjectLyr,"AUTO_ARRANGE") #Update the layer SubjectLyr = arcpy.mapping.ListLayers(mxd, SubjectLyr.name, df)[0] # change reference to layer in mxd sourceLayer = arcpy.mapping.Layer(wPath+"templates\\template.lyr") # get template layer arcpy.mapping.UpdateLayer(df, SubjectLyr, sourceLayer, True) ###Zoom to selection df.zoomToSelectedFeatures() lyrExtent = SubjectLyr.getSelectedExtent() df.extent = lyrExtent arcpy.mapping.ExportToPDF(mxd, r"F:\\testFiles\\output\\Population23_KDens_Map.pdf") print('DONE!')
mxd = arcpy.mapping.MapDocument( path to mxd ) df = arcpy.mapping.ListDataFrames(mxd)[0] ###UpdateLayer requires a data frame reference (returns 1st df) lyrFile = arcpy.mapping.Layer( path to lyr file ) ###This is a lyr file with pre-authored symbology you will apply to layer lyr = arcpy.mapping.ListLayers(mxd, "layer name", df)[0] ###A reference to the shapefile layer in MXD you want to update. arcpy.mapping.UpdateLayer(df, lyr, lyrFile, True) ###This will update ONLY the symbology
SubjectLyr = arcpy.mapping.Layer("Y:\Notification Radius Pkgs\Dave3\Shapefiles\Dave3Subject.shp") mxd = arcpy.mapping.MapDocument("Current") df = arcpy.mapping.ListDataFrames(mxd, "Radius Map")[0] wPath = "Y:\Notification Radius Pkgs\\" arcpy.mapping.AddLayer(df, SubjectLyr,"AUTO_ARRANGE") sourceLayer = arcpy.mapping.Layer(wPath+"Setup10\LayerFiles\Subject.lyr") arcpy.mapping.UpdateLayer(df, SubjectLyr, sourceLayer, True)
>>> SubjectLyr = arcpy.mapping.Layer("Y:\\Notification Radius Pkgs\\Dave3\\Shapefiles\\Dave3Subject.shp") >>> mxd = arcpy.mapping.MapDocument("CURRENT") >>> df = arcpy.mapping.ListDataFrames(mxd, "Radius Map")[0] >>> wPath = "Y:\\Notification Radius Pkgs\\" >>> arcpy.mapping.AddLayer(df, SubjectLyr,"AUTO_ARRANGE") >>> SubjectLyr = arcpy.mapping.ListLayers(mxd, SubjectLyr.name, df) >>> sourceLayer = arcpy.mapping.Layer(wPath+"Setup10\\LayerFiles\\Subject.lyr")[0] Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> TypeError: 'Layer' object does not support indexing #####Okay - get rid of the index >>> sourceLayer = arcpy.mapping.Layer(wPath+"Setup10\\LayerFiles\\Subject.lyr") >>> arcpy.mapping.UpdateLayer(df, SubjectLyr, sourceLayer, True) Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\utils.py", line 181, in fn_ return fn(*args, **kw) File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\mapping.py", line 1868, in UpdateLayer assert isinstance(update_layer, Layer) AssertionError >>> arcpy.mapping.Layer(wPath+"Setup10\LayerFiles\Subject.lyr") <map layer u'Dave502Subject'> >>> arcpy.mapping.UpdateLayer(df, SubjectLyr, sourceLayer, True) Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\utils.py", line 181, in fn_ return fn(*args, **kw) File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\mapping.py", line 1868, in UpdateLayer assert isinstance(update_layer, Layer) AssertionError ####What are the values of the variables? >>> print SubjectLyr [<map layer u'Dave3Subject'>] >>> print sourceLayer Dave502Subject
1>>> SubjectLyr = arcpy.mapping.Layer("Y:\\Notification Radius Pkgs\\Dave3\\Shapefiles\\Dave3Subject.shp") # use either \\ or / in paths 2>>> mxd = arcpy.mapping.MapDocument("CURRENT") 3>>> df = arcpy.mapping.ListDataFrames(mxd, "Radius Map")[0] 4>>> wPath = "Y:\\Notification Radius Pkgs\\" # same as in line 1 5>>> arcpy.mapping.AddLayer(df, SubjectLyr,"AUTO_ARRANGE") 6>>> SubjectLyr = arcpy.mapping.ListLayers(mxd, SubjectLyr.name, df) # change reference to layer in mxd 7>>> sourceLayer = arcpy.mapping.Layer(wPath+"Setup10\\LayerFiles\\Subject.lyr")[0] # same as in line 1 8>>> arcpy.mapping.UpdateLayer(df, SubjectLyr, sourceLayer, True)
