Hi,I have code that has been working from ArcObjects v 9.31 through 10.0 for more than a year.I just rebuilt it for ArcObjects 10.1 and all my feature queries are broken because...ISQLSyntax.GetSpecialCharacter(esriSQL_WildcardManyMatch) returns nullISQLSyntax.GetSpecialCharacter(esriSQL_DelimitedIdentifierPrefix) returns empty stringISQLSyntax.GetSpecialCharacter(esriSQL_DelimitedIdentifierSuffix) throws a COM exception with messageThe function ID is out of range.The source is esriDataSourceGDB.SdeWorkspace.1Error code -2147215854Is anyone seeing the same behavior?Is this something that is known to be broken in ArcObjects 10.1?
I am working in ArcGIS 10.1 and getting the same error message. The cause for me is when I add a layer to the map (SDE point or polygon, it doesn't matter) and join to a table (either an SDE table or DBF table) and I have labels turned on in the map for that layer. The labels don�??t have to be for a field that�??s in the join table either. As I pan around on the map, I receive the ArcMap Drawing Error "The function ID is out of range".If I turn the labels off, the ArcMap Drawing Error goes away. If I leave the labels on but remove the join, the ArcMap Drawing Error goes away. I tried the same scenario on an ArcMap 10.0 computer and there was no error message. This bug was introduced in 10.1.NOTE: in the scenario where the error message pops up, it's when joining the tax parcels (70,000 polygons) to a table with 100,000 records. I tried joining a shapefile with 70,000 polygons to a DBF of 75,000 records and no error message. I also joined an SDE layer of 4,500 polygons to an SDE table of 4,500 records and again no function ID is out of range error message.
Mr. Laue,Any update on this error; we are seeing the same thing with 10.1 and the ArcMap Drawing Error "The function ID is out of range". ESRI support's answer is to reload the data into ArcSDE but I am not sure that is the real answer.
I just migrated from ArcMap version 10.0 to 10.1 and i'm getting the same drawing error on projects where never seen before:function ID is out of range
