All,
I have what seems like a simple request, although it is apparently not.
i have a map div that contains a series of check boxes that represent layer ids. When a box is checked, an array is created and all checked boxes thus layer ids are added to the array. I now need to loop through the array, and turn on the first layer, wait some amount of time, turn that layer off, move to the next layer in the array and repeat, indefinitely. Only when a layer is added, or removed from the array would the loop restart. Below is what I have tried. But it doesn't work.
//Sleep Function
function sleep(milliseconds) {
var start = new Date().getTime();
for (var i = 0; i < 1e7; i++) {
if ((new Date().getTime() - start) > milliseconds){
break;
//Layer Looper Function
function startLoop(visibleLayerIds) {
for (var t = 0; t < layers.length; t++) {
layername = layers.id
// console.log(layername);
if ($.inArray(layername, visibleLayerIds) > -1) {
console.log(layername + " set to visible");
layers.show();
sleep(30000);
layers.hide();
console.log(layername + " set to invisible");
//Update Layer Visibility Function
on(dom.byId("layer0CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer1CheckBox"), "change", updateLayerVisibility);
function updateLayerVisibility () {
var inputs = query(".list_item");
var inputCount = inputs.length;
var visibleLayerIds = []
//Get Checked Layers
for (var i = 0; i < inputCount; i++) {
if (inputs.checked) {
visibleLayerIds.push(inputs.value);
startLoop(visibleLayerIds);
