<?xml version="1.0" ?><configuration> <identifylayeroption>visible</identifylayeroption> <identifytolerance>5</identifytolerance> <defaultzoomscale>5000</defaultzoomscale> <keepidentifyactive>true</keepidentifyactive> <returngeometryforzoom>true</returngeometryforzoom> <enablelineselect>true</enablelineselect> <enableextentselect>true</enableextentselect> <enablepolyselect>true</enablepolyselect> <enablecircleselect>true</enablecircleselect> <enableellipseselect>true</enableellipseselect> <enablemouseovergraphicsinfo>false</enablemouseovergraphicsinfo> <enablemouseoverrecordinfo>true</enablemouseoverrecordinfo> <enablegraphicclickinfo>true</enablegraphicclickinfo> <usemaptime>false</usemaptime> <infoautoclosemilliseconds>2000</infoautoclosemilliseconds> <autoactivatedtool>mappoint</autoactivatedtool> <excludebasemaps>true</excludebasemaps> <disablepopuplinks>false</disablepopuplinks> <disablelayerdropdown>false</disablelayerdropdown> <disablealllayerschoice>false</disablealllayerschoice> <replacenullswithemptystring>true</replacenullswithemptystring> <labels> <zoom2message>Click to Zoom to Point</zoom2message> <identifylabel>Identify</identifylabel> <resultslabel>Results</resultslabel> <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel> <pointlabel>Identify by Point</pointlabel> <linelabel>Identify by Polyline</linelabel> <rectlabel>Identify by Rectangle</rectlabel> <polylabel>Identify by Polygon</polylabel> <circlelabel>Identify by Circle</circlelabel> <ellipselabel>Identify by Ellipse</ellipselabel> <clearlabel>Clear</clearlabel> <loadinglabel>Loading...</loadinglabel> <removeresultmessage>Remove Result</removeresultmessage> <idfrom>Identify From</idfrom> <noresultsfoundlabel>No Results Found</noresultsfoundlabel> <resultsfoundlabel>Results Found</resultsfoundlabel> <alllayers>All Layers</alllayers> <layersremaining>layers remaining:</layersremaining> <copylabel>Copy results to clipboard</copylabel> </labels> <layers onlythese="false"> <layer> <name>Fields</name> <id>2</id> <url>http://10.16.195.34:6080/arcgis/rest/services/General/General/MapServer</url> <fields> <field name="Field_ID" alias="Field Name"/> <field name="Shape.STLength()" alias="Perimeter "/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Camps</name> <id>3</id> <url>http://10.16.195.34:6080/arcgis/rest/services/General/General/MapServer</url> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Stations</name> <id>4</id> <url>http://10.16.195.34:6080/arcgis/rest/services/General/General/MapServer</url> <fields> <field name="Name" alias="Name"/> <field name="Shape.STLength()" alias="Perimeter"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Well Locations</name> <id>5</id> <url>http://10.16.195.34:6080/arcgis/rest/services/GeneralServices/General_Services/MapServer</url> <fields> <field name="Name" alias="Name"/> <field name="Shape.STLength()" alias="Perimeter " numberformat="0|,1|."/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Generators</name> <id>6</id> <url>http://10.16.195.34:6080/arcgis/rest/services/GeneralServices/General_Services/MapServer</url> <fields> <field name="Name" alias="Name"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Helipads</name> <id>7</id> <url>http://10.16.195.34:6080/arcgis/rest/services/GeneralServices/General_Services/MapServer</url> <fields> <field name="Name" alias="Name"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Villages</name> <id>8</id> <url>http://10.16.195.34:6080/arcgis/rest/services/GeneralServices/General_Services/MapServer</url> <fields> <field name="Name" alias="Name"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Roads</name> <id>1</id> <url>http:/10.16.195.34:6080/arcgis/rest/services/GeneralServices/General_Services/MapServer/1</url> <fields> <field name="Name" alias="Name"/> <field name="Shape.STLength()" alias="Perimeter"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Well Production FlowLines</name> <id>0</id> <url>http://10.16.195.34:6080/arcgis/rest/services/Reservoir/Reservoir/MapServer</url> <fields> <field name="Name" alias="Name"/> <field name="Field_ID" alias="Field_ID"/> <field name="Production_Hours" alias="Production_Hours"/> <field name="Oil" alias="Oil"/> <field name="Water" alias="Water"/> <field name="Gas" alias="Gas"/> <field name="Test_Oil" alias="Test_Oil"/> <field name="Test_Water" alias="Test_Water"/> <field name="Test_Gas" alias="Test_Gas"/> <field name="Intake_Pressure" alias="Intake_Pressure"/> <field name="WH_Pressure" alias="WH_Pressure"/> <field name="Choke" alias="Choke"/> <field name="Water_Injection" alias="Water_Injection"/> <field name="Water_Rate" alias="Water_Rate"/> <field name="Date" alias="Date"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Oil Wells</name> <id>2</id> <url>http://10.16.195.34:6080/arcgis/rest/services/Reservoir/Reservoir/MapServer</url> <fields> <field name="Name" alias="Name"/> <field name="Date" alias="Date"/> <field name="Field_ID" alias="Field_ID"/> <field name="Production_Hours" alias="Production_Hours"/> <field name="Oil" alias="Oil"/> <field name="Water" alias="Water"/> <field name="Gas" alias="Gas"/> <field name="Test_Oil" alias="Test_Oil"/> <field name="Test_Water" alias="Test_Water"/> <field name="Test_Gas" alias="Test_Gas"/> <field name="Intake_Pressure" alias="Intake_Pressure"/> <field name="WH_Pressure" alias="WH_Pressure"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Water Wells</name> <id>1</id> <url>http:/10.16.195.34:6080/arcgis/rest/services/Reservoir/Reservoir/MapServer/1</url> <fields> <field name="Name" alias="Name"/> <field name="Water_Rate" alias="Water_Rate"/> <field name="Date" alias="Date"/> <field name="Field_ID" alias="Field_ID"/> <field name="Production_Hours" alias="Production_Hours"/> <field name="Water_Injection" alias="Water_Injection"/> <field name="Intake_Pressure" alias="Intake_Pressure"/> <field name="WH_Pressure" alias="WH_Pressure"/> <field name="Choke" alias="Choke"/> </fields> <links/> <zoomscale>2000</zoomscale> <forcescale>true</forcescale> </layer> </layers> <symbols> <simplefillsymbol color="0x448ccb" alpha="0.4" style="solid"> <outline color="0x448ccb" alpha="0.8" width="2" style="solid"/> </simplefillsymbol> <simplemarkersymbol color="0x448ccb" alpha="0.8" style="circle" angle="0" size="12"> <outline color="0xffffff" alpha="0.8" width="1" style="solid"/> </simplemarkersymbol> <simplelinesymbol color="0x448ccb" alpha="0.8" width="2" style="solid"/> <picturemarkersymbol url="assets/images/i_info.png" height="30" width="30" xoffset="0" yoffset="0" angle="0"/> </symbols></configuration>
<layers onlythese="true">
