var kmlExtent, layers = kml.getLayers(); dojo.forEach(layers, function(lyr) { if ( lyr.graphics && lyr.graphics.length > 0 ) { var lyrExtent = esri.geometry.geographicToWebMercator( esri.graphicsExtent(lyr.graphics) ); if ( globals.kmlExtent ) { kmlExtent = kmlExtent.union(lyrExtent); } else { kmlExtent = lyrExtent; } }); map.setExtent(kmlExtent);
<!doctype html> <html lang="en"> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title> </title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/esri/dijit/css/Popup.css"/> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { margin: 0; padding: 0; } #meta { position: absolute; left: 20px; bottom: 20px; width: 300px; height: 100px; z-index: 40; background: #fff; color: #777; padding: 5px; border: 5px solid #777; -webkit-border-radius: 5px; -moz-border-radius: 5px; border-radius: 5px; font-family: arial; font-size: 0.9em; } #meta h3 { color: #000; font-size: 1.1em; padding: 0px; margin: 0px; display: inline-block; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.layers.KMLLayer"); dojo.require("esri.dijit.Popup"); var map; function init() { var initExtent = new esri.geometry.Extent({"xmin":-13947963,"ymin":4434797,"xmax":-13170751,"ymax":4779680,"spatialReference":{"wkid":102100}}); var popup= new esri.dijit.Popup(null,dojo.create("div")); map = new esri.Map("map",{ infoWindow: popup, extent: initExtent }); //map = new esri.Map("map",{ extent: initExtent }); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); var kmlUrl = "http://dl.dropbox.com/u/21472423/esri/kml-folder.kml"; var kml = new esri.layers.KMLLayer(kmlUrl); map.addLayer(kml); dojo.connect(kml, 'onLoad', function() { var layers = kml.getLayers(); var kmlLayerExtent; dojo.forEach(layers, function(l) { // get the extent for the layer var ext = esri.geometry.geographicToWebMercator(esri.graphicsExtent(l.graphics)); // if the layer's extent is valid, union it with the rest of the layer // extents. layers with a single point do not result in a valid extent if ( ext ) { (kmlLayerExtent) ? kmlLayerExtent.union(ext): kmlLayerExtent = ext; } }); map.setExtent(kmlLayerExtent); }); dojo.connect(map, 'onLoad', function() { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); }); } dojo.ready(init); </script> </head> <body class="tundra"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> <div id="meta"> <h3>Display KML Using a <a href="http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/kmllayer.htm">KMLLayer</a></h3> <br /> The map displays a simple KML file that was created using Google Earth and is hosted on an Esri server. Symbology and attributes are honored. <div> </div> </div> </body> </html>
dojo.connect(kml, 'onLoad', function () { dojo.style(dojo.byId('loading'), 'display', 'none'); //AutoExtent var kmlExtent, layers = kml.getLayers(); dojo.forEach(layers, function(lyr) { if ( lyr.graphics && lyr.graphics.length > 0 ) { var lyrExtent = esri.geometry.geographicToWebMercator(esri.graphicsExtent(lyr.graphics) ); kmlExtent = lyrExtent; } }); map.setExtent(kmlExtent); });
dojo.connect(kml, 'onLoad', function() { dojo.style(dojo.byId('loading'), 'display', 'none'); // Add your snippet here });
