Ronald, Your welcome. I am glad I finally took the time to look into this as it really was not that hard in the end. That EPA layer is coming from a 9.3.1 Server and that is why there is no symbology.
Ronald, Here it is. Let me know how it goes. May basic testing is working great.
Ronald, Do you need compiled or source or does it matter?
Ronald, Are you up for some beta testing of my TOCWidget that supports Identity Manager tokens?
Ronald, I have updated the TOCWidget, eMapScitcherWidget, and the dynamic legend widget. You should be able to use the OTB esri Legend widget with my eMapSwitcherWidget (with the layer list enabled) or try out my partial/Beta secure services ability on the TOC Widget. The TOC Widget supports Tokens WHEN they are provided in the main config.xml or a part of the layer url. IT DOES NOT yet work with token provided throught the identity manager.
Ronald, Sorry about your name (just bad typing). I have found the solution that esri has in their MapSwitcherWidget that addresses the issue in the Legend and have applied it to my eMapSwitcherWidget and TOCWidget. I just need to test more and then release these fixes. The TOCWidget will be a longer wait as I am attempting to add support for secure services.
Roland, Hmm... I have made some progress... If you remove the eMapSwitcher, MapSwitcher, TOCWidget and only have the OTB esri Legend widget it will not honor scale dependency either. There seem to be an issue that the esri MapSwitcher fixes for the legend widget.
Ronald, Do you mind setting up the test app back to the senario in question (i.e. eMapSwitcher, TOCWidget, OTB esri Legend widget)?
<widget left="0" top="0" config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/> <map wraparound180="true" addarcgisbasemaps="false" initialextent="-13906490 5826218 -13430340 6280858" fullextent="-13906490 5826218 -13430340 6280858" top="40"> <basemaps> <layer type="tiled" label="Streets" url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" visible="true"/> <layer type="tiled" label="Topo" url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer" visible="false"/> <layer type="tiled" label="Aerial" url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" visible="false"/> </basemaps> <operationallayers> <layer type="dynamic" label="WRIA/WAU" url="http://hammerhead.nwifc.org:8080/ArcGIS/rest/services/Public/WriaWau/MapServer" visible="true"/> <layer type="dynamic" label="Office Location" url="http://hammerhead.nwifc.org:8080/ArcGIS/rest/services/Public/Office_Location/MapServer" visible="true"/> <layer type="dynamic" label="County" url="http://hammerhead.nwifc.org:8080/ArcGIS/rest/services/Public/County/MapServer" visible="true"/> </operationallayers> </map> <widgetcontainer layout="float"> <widget label="Map Legend" x="80" y="100" preload="open" icon="assets/images/legend32.png" config="widgets/Legend /LegendWidget.xml" url="widgets/Legend/LegendWidget.swf"/> </widgetcontainer>
