//Function to initialize the map and read data from Configuration file function Init() { ShowLoadingMessage('Loading...'); esri.config.defaults.io.proxyUrl = "proxy.ashx"; esri.config.defaults.io.alwaysUseProxy = false; esri.config.defaults.io.timeout = 600000; //timeout for querytask dojo.xhrGet({ url: "Config.txt", handleAs: "json", preventCache: true, load: function (responseObject, ioArgs) { dojo.byId('divLoadMessage').innerHTML = responseObject.SplashScreenMessage; dijit.byId('dialogLoadMessage').show();
var myMessage = "welcome blurb for your site"; dojo.byId('divLoadMessage').innerHTML = myMessage; dijit.byId('dialogLoadMessage').show();
<div id="dialogLoadMessage" dojotype="dijit.Dialog" style="width: 350px;"> <table> <tr> <td> <div id="divLoadMessage" style="background: black; color: White;"> </div> </td> </tr> <tr> <td align="center"> <div class="divOk" onclick="dijit.byId('dialogLoadMessage').hide();"> OK</div> </td> </tr> </table> </div>
esri.config.defaults.io.proxyUrl = "proxy.ashx"; esriConfig.defaults.io.alwaysUseProxy = false; dojo.xhrGet({ url: "Config.txt", handleAs: "json", preventCache: true, load: function (responseObject, ioArgs) { var mapExtent = responseObject.DefaultExtent; var zoomExtent = mapExtent.split(","); var startExtent = new esri.geometry.Extent(parseFloat(zoomExtent[0]), parseFloat(zoomExtent[1]), parseFloat(zoomExtent[2]), parseFloat(zoomExtent[3]), new esri.SpatialReference({ wkid: 2269 })); map = new esri.Map("map"); dojo.byId('divLoadMessage').innerHTML = responseObject.SplashScreenMessage; dijit.byId('dialogLoadMessage').show(); hasCustomRenderer = responseObject.CustomRenderer; rendererColor = responseObject.RendererColor; map.setExtent(startExtent); locatorURL = responseObject.Locator; defaultAddress = responseObject.DefaultAddress; helpFileURL = responseObject.helpURL; defaultCmnt = responseObject.DefaultCmnt; devPlanLayerURL = responseObject.DevPlanLayer; commentLayerURL = responseObject.CommentLayer;
<div id="dialogLoadMessage" dojotype="dijit.Dialog" style="width: 350px;"> <table> <tr> <td> <div id="divLoadMessage" style="background: black; color: White;"> </div> </td> </tr> <tr> <td align="center"> <div class="divOk" onclick="dijit.byId('dialogLoadMessage').hide();"> OK</div> </td> </tr> </table> </div> <div id="dojoStandBy" dojotype="dojox.widget.Standby" color="black"> </div> </div> </body> </html>
'CustomRenderer' : false, 'RendererColor' : "#1C86EE", 'SplashScreenMessage' : "<big><b>Land Use Public Notification</b> <br/> <hr/> <br/>The <b>Land Use Public Notification</b> application allows local government staff to identify properties within a given distance (buffer) of a subject property and generate mailing labels and/or a structured text file for owners and occupants that fall within the buffer.<br/><br/>This application is typically used by local planning and zoning officials, but can be used by any agency looking to notify property owners and occupants of a formal action being taken. The process of public notification allows adjoining or nearby property owners, and others, the opportunity to look at a proposed development, consider the likely impacts the proposal may have on them, and provide comment (either positive or negative) about the proposal prior to a decision being made.<big/><br/><br/>", 'BaseMapLayers' : [ {"Key": "parcelMap", "ThumbnailSource": "images/Parcel map.png", "Name" : "Parcels", MapURL: "http://webags.co.washington.or.us/ArcGIS/rest/services/Washco_primary_basemap_SP/MapServer"}, {"Key": "hybridMap", "ThumbnailSource": "images/Imagery Hybrid.png", "Name" : "Imagery", MapURL: "http://webags.co.washington.or.us/ArcGIS/rest/services/Washco_orthos2008_StatePlane/MapServer"} ] }
