Dear all,
i am trying to add polylin, point geometry to feature layer but its not saving in the database. actually data is stored in oracle spatial and i am publishing featurelayer from arcgis server.
after i add geometry it adds but when i refresh it disappear another thing when i add geometry i check in oracle it doesn't insert
here is following code please check it
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Landuse</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
<style>
html, body {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
overflow:hidden;
#header {
border:solid 2px #462d44;
background:#fff;
color:#444;
-moz-border-radius: 4px;
border-radius: 4px;
font-family: sans-serif;
font-size: 1.1em
padding-left:20px;
#map {
padding:1px;
border:solid 2px #444;
border-radius: 4px;
#rightPane {
border:none;
padding: 0;
width:228px;
.templatePicker {
border: solid 2px #444;
</style>
<script src="http://js.arcgis.com/3.13/"></script>
<script>
var map;
var _public = {};
require([
"esri/map",
"esri/toolbars/draw",
"esri/toolbars/edit",
"esri/graphic",
"esri/config",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ImageParameters",
"esri/layers/FeatureLayer",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/dijit/editing/TemplatePicker",
"dojo/_base/array",
"dojo/_base/event",
"dojo/_base/lang",
"dojo/parser",
"dijit/registry",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dijit/form/Button", "dojo/domReady!"
], function(
Map, Draw, Edit, Graphic, esriConfig,
ArcGISDynamicMapServiceLayer,
ImageParameters,
FeatureLayer,
SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
TemplatePicker,
arrayUtils, event, lang, parser, registry
parser.parse();
// refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
esriConfig.defaults.io.proxyUrl = "/proxy/";
// This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
esriConfig.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
map = new Map("map", {
sliderOrientation : "horizontal"
var imageParameters = new ImageParameters();
imageParameters.format = "jpeg"; //set the image type to PNG24, note default is PNG8.
//Takes a URL to a non cached map service.
var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://192.168.100.72:6080/arcgis/rest/services/ksa_bound/MapServer", {
"opacity" : 0.5,
"imageParameters" : imageParameters
map.addLayer(dynamicMapServiceLayer);
map.on("layers-add-result", initEditing);
var landusePointLayer = new FeatureLayer("http://192.168.100.72:6080/arcgis/rest/services/ksa_cities_fl/MapServer/0", {
mode: FeatureLayer.MODE_SNAPSHOT,
outFields: ["*"]
var landuseLineLayer = new FeatureLayer("http://192.168.100.72:6080/arcgis/rest/services/ksa_mot_roads/FeatureServer/0", {
outFields: ["*"]
var landusePolygonLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/FeatureServer/9", {
outFields: ["*"]
map.addLayers([landusePointLayer, landuseLineLayer, landusePolygonLayer]);
function initEditing(evt) {
console.log("initEditing", evt);
_public._kabevt=evt;
// var map = this;
var currentLayer = null;
var layers = arrayUtils.map(evt.layers, function(result) {
return result.layer;
_public._kablayers=layers;
console.log("layers", layers);
var editToolbar = new Edit(map);
editToolbar.on("deactivate", function(evt) {
currentLayer.applyEdits(null, [evt.graphic], null);
console.log("mkabeer",currentLayer );
_public._kabcurrentLayer=currentLayer.applyEdits(null, [evt.graphic], null);
arrayUtils.forEach(layers, function(layer) {
var editingEnabled = false;
layer.on("dbl-click", function(evt) {
event.stop(evt);
if (editingEnabled === false) {
editingEnabled = true;
editToolbar.activate(Edit.EDIT_VERTICES , evt.graphic);
} else {
currentLayer = this;
editToolbar.deactivate();
layer.on("click", function(evt) {
event.stop(evt);
if (evt.ctrlKey === true || evt.metaKey === true) { //delete feature if ctrl key is depressed
layer.applyEdits(null,null,[evt.graphic]);
editingEnabled=false;
var templatePicker = new TemplatePicker({
featureLayers: layers,
rows: "auto",
columns: 2,
grouping: true,
style: "height: auto; overflow: auto;"
}, "templatePickerDiv");
templatePicker.startup();
var drawToolbar = new Draw(map);
var selectedTemplate;
templatePicker.on("selection-change", function() {
if( templatePicker.getSelected() ) {
selectedTemplate = templatePicker.getSelected();
switch (selectedTemplate.featureLayer.geometryType) {
case "esriGeometryPoint":
drawToolbar.activate(Draw.POINT);
break;
case "esriGeometryPolyline":
drawToolbar.activate(Draw.POLYLINE);
break;
case "esriGeometryPolygon":
drawToolbar.activate(Draw.POLYGON);
break;
drawToolbar.on("draw-end", function(evt) {
console.log(evt);
drawToolbar.deactivate();
var newAttributes = lang.mixin({}, selectedTemplate.template.prototype.attributes);
console.log("newAttributes", newAttributes)
var newGraphic = new Graphic(evt.geometry, null, newAttributes);
console.log("newGraphic", newGraphic)
selectedTemplate.featureLayer.applyEdits([newGraphic], null, null);
_public._kabselectedTemplate=selectedTemplate;
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="gutters:true, design:'headline'" style="width:100%;height:100%;">
<div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">Use ctrl or cmd + click on graphic to delete. Double click on graphic to edit vertices. </div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
<div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
<div id="templatePickerDiv"></div>
</div>
</div>
</body>
</html>
here is the console example it shows KSA_MOT_ROADS_ID: 13033
newGraphic Object {geometry: Object, symbol: null, attributes: Object, infoTemplate: undefined, declaredClass: "esri.Graphic"â¦}_count: 1_extent: Object_graphicsLayer: Object_layer: Object_offsets: Array[1]_shape: Objectattributes: ObjectIGDS_CLASS: nullIGDS_COLOR: nullIGDS_GRAPHIC_GROUP: nullIGDS_STYLE: nullIGDS_WEIGHT: nullKSA_MOT_ROADS_ID: 13033__proto__: Objectgeometry: Object_path: 0cache: Objectpaths: Array[1]spatialReference: Objecttype: "polyline"__proto__: ObjectinfoTemplate: undefinedsymbol: null__proto__: Object
Kabeer
