Hello Shohreh,
The OSM tools have been around for many releases of ArcGIS. You can get the 10.4 version here:
https://www.arcgis.com/home/item.html?id=c18d3d0d5c62465db60f89225fdd2698
I would still caution you that if your goal in the dissertation is closest facility, then do not spend time maintaining the data unless you have other uses for it. Use the ready-to-use services in ArcGIS and call the closest facility solver. These ready-to-use services show up in the Catalog once you have signed into ArcGIS.
You can set up a trial account that gives you 200 credits for 21 day. Details here:
http://www.arcgis.com/features/free-trial.html
Regards,
Jay Sandhu
Hi Jay,
Thank you for your prompt reply.
I have ArcGIS 10.4 installed on my laptop and this editor tool is for 10.5 and isn't compatible with 10.4.
Also, my other concern is about editing London OSM roads, which consists of almost 200,000 feature!!
If you are using Open Street Map data, I would suggest that you look at the tools at the link below to help build a network dataset that can be used with ArcGIS.
ArcGIS Editor for OpenStreetMap | Overview
Alternatively you can use the closest facility service on ArcGIS.com and do your analysis there. You will be paying some credits to use that. But the network of London is available ready to use.
What are the ArcGIS Online network analysis services?—Help | ArcGIS Desktop
Hi Olawumi Lanlehin,
Have you figured out the problem with London road network?
Currently, I am doing my dissertation and I need to run a network analysis (Closest facilities) on London roads. I have a similar problem as yours and was looking through websites and blogs to find a solution which I came across to the discussion that you've started.
I just was wondering whether you might be to help me now. Many thanks in advance.
looking forward to hearing from you.
Regards
Shohreh
Your Incidents and Facilities are on street elements that are either not connected to the rest of the network (for example because of little gaps from the endpoints to the next street elements), or there are some restrictions active that prevent using this street (use the network identify tool to check, or turn restrictions off in the analysis settings).For example with the field calculator and a little math using a speed value (30mph?) and the shape length attribute.
Location XY is on a non-traversable network element position.Warning: 0 location(s) in "Incidents" are valid. Need at least 1 valid location(s).Warning: 0 location(s) in "Facilities" are valid. Need at least 1 valid location(s).Error: Insufficient number of valid locations in "Facilities" or "Incidents".
My minute Field rows are all null value, how can I calculate this to return figures?
I am not familiar with the OSM data quality of the London area, but when I used OSM Data from Hamburg with the Network Analyst I for example had problems with oneway streets (editing needed for ArcGIS to recognize them properly), prohibited turns onto highways (missing z-levels, bad connectivity set-up) and maxspeed data (many values not existent).Not being able to perfom some types of analysis like Closest Facility seems rather odd though. What exactly happens when you try to do that?
Short answer. A lot of things, especially:Connectivity and Impedance ValuesMy suggestion is to get more familiar with NA by working through the tutorial.
What could be wrong?
