app.map.infoWindow.set("popupWindow", false);
function initializeSidebar(map){ var popup = map.infoWindow; //when the selection changes update the side panel to display the popup info for the //currently selected feature. connect.connect(popup, "onSelectionChange", function(){ displayPopupContent(popup.getSelectedFeature()); }); //when the selection is cleared remove the popup content from the side panel. connect.connect(popup, "onClearFeatures", function(){ dom.byId("featureCount").innerHTML = "Click Identify Tool to select feature(s)"; registry.byId("leftPane").set("content", ""); domUtils.hide(dom.byId("pager")); }); //When features are associated with the map's info window update the sidebar with the new content. connect.connect(popup, "onSetFeatures", function(){ displayPopupContent(popup.getSelectedFeature()); dom.byId("featureCount").innerHTML = popup.features.length + " feature(s) selected"; //enable navigation if more than one feature is selected popup.features.length > 1 ? domUtils.show(dom.byId("pager")) : domUtils.hide(dom.byId("pager")); }); } function displayPopupContent(feature){ if(feature){ var content = feature.getContent(); registry.byId("leftPane").set("content", content); } } function selectPrevious(){ app.map.infoWindow.selectPrevious(); } function selectNext(){ app.map.infoWindow.selectNext(); } function clearContent() { registry.byId("leftPane").set("content", ""); domUtils.hide(dom.byId("pager")); }
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Identify with Popup</title> <link rel="stylesheet" href="https://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body, #map { height:100%; width:100%; margin:0; padding:0; } /*---------------------------------------------------------------------------------------------------------*/ /* NewLayer window in the top right corner*/ .divLayerContainerNewLayer { position: absolute; top: 45px; right: 0px; width: 200px; z-index: 1000; } .divLayerHolderNewLayer { width: 190px; height: 400px; background: rgba(0,0,0,0.9); -pie-background: rgba(0,0,0,0.9); -moz-border-radius: 5px; -webkit-border-radius: 5px; border-radius: 5px; behavior: url("styles/PIE.htc"); opacity:.8; } .divLayerContentHolderNewLayer { overflow: auto; padding: 5px; height: 390px; width: 185px; } #leftPane{ background-color:transparent; border:1px solid red; font-family:tahoma; font-size:10px; height: 350px; } </style> <script src="https://js.arcgis.com/3.9/"></script> <script> var map; require([ "esri/map", "esri/InfoTemplate", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters", "esri/dijit/Popup", "dojo/_base/array", "esri/Color", "dojo/dom-construct", "dojo/domReady!" ], function ( Map, InfoTemplate, ArcGISDynamicMapServiceLayer, SimpleFillSymbol, SimpleLineSymbol, IdentifyTask, IdentifyParameters, Popup, arrayUtils, Color, domConstruct ) { var identifyTask, identifyParams; /* var popup = new Popup({ fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25])) }, domConstruct.create("div")); */ map = new Map("map", { basemap: "gray", center: [-77.4329, 37.5410], zoom: 7 // infoWindow: popup }); map.on("load", mapReady); var parcelsURL = "https://fwisweb1.dgif.virginia.gov/arcgis/rest/services/Public/DGIF_Public/MapServer"; map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL, { opacity: .55 })); function mapReady () { map.on("click", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new IdentifyTask(parcelsURL); identifyParams = new IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [0, 4]; identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; } function executeIdentifyTask (event) { identifyParams.geometry = event.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask .execute(identifyParams) .addCallback(function (response) { // response is an array of identify result objects // Let's return an array of features. return arrayUtils.map(response, function (result) { var feature = result.feature; var layerName = result.layerName; feature.attributes.layerName = layerName; if (layerName === 'Birding Trail Sites') { var taxParcelTemplate = new InfoTemplate("", "${LOOP_NAME} <br/> Owner of record: ${SITE_NAME}"); feature.setInfoTemplate(taxParcelTemplate); } else if (layerName === 'Birding Trail Loops') { console.log(feature.attributes.PARCELID); var buildingFootprintTemplate = new InfoTemplate("", "Parcel ID: ${Loop_Name}"); feature.setInfoTemplate(buildingFootprintTemplate); } return feature; }); }); // InfoWindow expects an array of features from each deferred // object that you pass. If the response from the task execution // above is not an array of features, then you need to add a callback // like the one above to post-process the response and return an // array of features. //map.infoWindow.setFeatures([deferred]); //map.infoWindow.show(event.mapPoint); var popup = map.infoWindow; connect.connect(popup, "onSelectionChange", function(){ displayPopupContent(popup.getSelectedFeature()); }); //When features are associated with the map's info window update the sidebar with the new content. connect.connect(popup, "onSetFeatures", function(){ displayPopupContent(popup.getSelectedFeature()); }); } // END OF executeIdentifyTask function displayPopupContent(feature){ if(feature){ var content = feature.getContent(); registry.byId("leftPane").set("content", content); } } }); </script> </head> <body> <div id="map"> <div id="divLayerContainerNewLayer" class="divLayerContainerNewLayer hideContainerHeightNewLayer" > <div id="divLayerHolderNewLayer" class="divLayerHolderNewLayer"> <div id="divLayerContainerHolderNewLayer" style="position: relative"> <div id="divLayerContentHolderNewLayer" class="divLayerContentHolderNewLayer" style="position: absolute; overflow: hidden"> <div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> </div> </div> </div> </div> </div> </body> </html>
var templateBirdingTrailHeads = new InfoTemplate(); templateBirdingTrailHeads.setTitle("Birding Trail Heads"); templateBirdingTrailHeads.setContent("<table><tr><td><b>Loop Name</b></td><td>${LOOP_NAME}</td></tr></table>" + "<table><tr><td><b>Site Name</b></td><td>${SITE_NAME}</td></tr></table> " + "<table><tr><td><b>Pahse</b></td><td>${Phase}</td></tr></table> " ); var flBirdingTrailHeads = new FeatureLayer("https://fwisweb1.gov/arcgis/rest/services/Public/BirdingWildlifeTrail/MapServer/0", { mode: FeatureLayer.MODE_ONDEMAND, infoTemplate: templateBirdingTrailHeads, outFields: ['*'] }); app.map.addLayer(flBirdingTrailHeads);
var layer1 = new ArcGISDynamicMapServiceLayer("https://fwisweb1.gov/arcgis/rest/services/Public/BirdingWildlifeTrail/MapServer", { id: "layer1" }); app.map.addLayers([layer1]);
layer = new ArcGISDynamicMapServiceLayer("https://fwisweb1.dgif.virginia.gov/arcgis/rest/services/Public/BirdingWildlifeTrail/MapServer", {"imageParameters": imageParameters}); map.addLayer(layer);
