class ToolValidator: """Class for validating a tool's parameter values and controlling the behavior of the tool's dialog.""" def __init__(self): """Setup arcpy and the list of tool parameters.""" import arcpy self.params = arcpy.GetParameterInfo() def initializeParameters(self): """Refine the properties of a tool's parameters. This method is called when the tool is opened.""" self.params[1].parameterDependencies = [0] # set the parameter dependency for Field to the FC return def updateParameters(self): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parmater has been changed.""" import arcpy FC = self.params[0].value fldName = self.params[1].value vList = [] #use a cursor to get values of selected field into vList rows = arcpy.SearchCursor(FC) for row in rows: fldVal = str(row.getValue(fldName)) vList.append(fldVal) self.params[2].filter.list = vList #fill the Values Parameter with the selected field´s values return def updateMessages(self): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return
Thanks very much. This is exactly what I needed to accomplish and I learned about validation in the processes.
