Bakht Ali, This sample shows using url parameters:http://resources.arcgis.com/en/help/flex-api/samples/#/Pass_URL_parameters/01nq00000051000000/
Bakht Ali,Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).Follow these steps as shown in the below graphic:
Bakht Ali,Roberts esearch allows you to perform that kind of search from the URL (not sure if the arabic words would work though), see his documentation here:https://github.com/rscheitlin/eSearch/raw/master/Enhanced%20Search%20Widget%20URL%20Search%20Configuration.pdfRegardsAnthony
Bakht Ali,A 400 error on this widget means that the query you are trying to use is invalid, have you set up the configuration file to work against your layers?RegardsAnthony
