When configuring the Open Data site, is there a way to switch back to the Wizard once you've been working in the Code section? I switched to the Code when working on the layout, and now the Wizard tab is greyed out.
There's a pop-up warning you about making hand edits to the HTML and if you do, you will not be able to get back to the wizard. If you really need to get back to the wizard, the easiest method I've found is to just create another site.
