Could it be that this is a secured service, as it requires AGOL for Organization credentials, and both the OOTB ... Route Widgets
That seems to be the case using the old URL did not require authentication and the new one does. As I do not have an AGOL account I am now unable to test/develop using the new url, so I guess this widget will become obsolete.
Does anyone know where I would change the uncompiled code on the Route Widget to allow the use of secured services?
<?xml version="1.0" ?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Routing Widget developed by Robert Scheitlin (original developed by Imtiaz Ahmed // using the esri routing sample). // // dirlengthunits: esriMiles or esriKilometers // //////////////////////////////////////////////////////////////////////////////// --> <configuration> <!-- <routetasksolver>http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route</routetasksolver> --> <routetasksolver>http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World</routetasksolver> <!-- <reversegeocode>http://tasks.arcgisonline.com/ArcGIS/rest/services/Locators/TA_Address_NA_10/GeocodeServer</reversegeocode> --> <reversegeocode>http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</reversegeocode> <!-- <singlelinegeocode>http://tasks.arcgisonline.com/ArcGIS/rest/services/Locators/TA_Address_NA_10/GeocodeServer</singlelinegeocode> --> <singlelinegeocode>http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</singlelinegeocode> <directionslanguage>en_US</directionslanguage> <dirlengthunits>esriMiles</dirlengthunits> <!-- alttxtbgclr = Route directions alternating text background color --> <alttxtbgclr>0xd7d7d7</alttxtbgclr><!-- pale gray --> <routesegment color="0xfbec5b" animate="true" alpha="0.8" width="8" /> <showdirectionarrows>true</showdirectionarrows> <manualaddtooltip>Click on Map to Add</manualaddtooltip> <prepmap>Preparing Map</prepmap> <genpdf>Generating PDF...</genpdf> <createroutetooltip>Create Route</createroutetooltip> <dirbtntooltip>Directions</dirbtntooltip> <printtooltip>Print</printtooltip> <addbarrierlabel>Add Barrier</addbarrierlabel> <addstoplabel>Add Stop</addstoplabel> <resetbtnlabel>Reset</resetbtnlabel> <resetbtntooltip>Reset/Clear Stops</resetbtntooltip> <locateinstructions>Enter an address, then press enter.</locateinstructions> <printmapbtnlabel>Print Map</printmapbtnlabel> <exportpdfbtnlabel>Save Map to PDF</exportpdfbtnlabel> <includemaplabel>Include Map</includemaplabel> <pdfgenerationwarning>If you choose to save a PDF then please be patient.<br />A save dialog will open once the PDF has been generated.</pdfgenerationwarning> <computingmsg>Computing Route...</computingmsg> <promotestoptooltip>Promote selected stop</promotestoptooltip> <demotestoptooltip>Demote selected stop</demotestoptooltip> <calculateshortestlbl>Calculate Shortest:</calculateshortestlbl> <timeradiobtnlbl>Time</timeradiobtnlbl> <distanceradiobtnlbl>Distance</distanceradiobtnlbl> <findbestseqlbl>Find Best Sequence</findbestseqlbl> <return2firststop>Return to First Stop</return2firststop> <zoomfullroutetooltip>Click to zoom to full route</zoomfullroutetooltip> <getdirectionslbl>Click 'Get Directions' above to display driving directions here...</getdirectionslbl> <summarydistancelbl>Total Distance:</summarydistancelbl> <summarytimelbl>Total Time:</summarytimelbl> <routeerrormsg>Clear and start again or add another valid stop.</routeerrormsg> <directionssegmenttooltip>Click individual segment to zoom to that segment.</directionssegmenttooltip> <stopaddresslbl>Address</stopaddresslbl> <barrierlbl>Barrier</barrierlbl> <alertmaxstops>Routes are limited to 10 stops</alertmaxstops> <alertmaxstopstitle>Max Stops Reached</alertmaxstopstitle> <alertmaxbarriers>Routes are limited to 10 barriers</alertmaxbarriers> <alertmaxbarrierstitle>Max Barriers Reached</alertmaxbarrierstitle> <manualaddstatus>Add Route Locations</manualaddstatus> <reversegeocodeerror>This location does not have a known address</reversegeocodeerror> <nolocationlabel>This loaction was not found.</nolocationlabel> </configuration>
