Hi all,
I'm trying to separate MapView and Map. Following the guide "Use the MVVM design pattern—ArcGIS Runtime SDK for .NET | ArcGIS for Developers ".
But it seems unable to a hittest in the viewmodel, because the viewmodel have no reference to the MapView and the hittest method need a MapView as a parameter.
I implemented a EventToCommand trigger to bind the MapViewTapped event to a RelyCommand, using the mvvm light toolkit library provided by MVVM Light Toolkit .
I could get the EventArgs (Esri.ArcGISRuntime.Controls.MapViewInputEventArgs), but not the sender which should be the instance of the MapView control.
Hope somebody show me a better solution, thanks in advance.
