Greetings,
We are using the esri 4.11 javascript library for our mapping solution. For our development environment, we have been using the default configuration which connects to the remote tile server (https://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer). Now we need to point to our local in-house server. How and where is that configured?
Jeff
Jeff,
Have you seen this sample?
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=basemap-custom
Basically you would use that sample but replace web tile layer with
<SPAN class="keyword token">var</SPAN> layer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">TileLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://your server url/arcgis/rest/services/your tile service/MapServer"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Nobody?
OK, we were using ArcGISDynamicMapServiceLayer and that didn't work. The one you are suggesting works. I see now it's a version thing.
Thank you for your help.
