function openEdit(){ editLayersAdded = dojo.connect(map,'onLayersAddResult',addEditor); StructurePoints = new esri.layers.FeatureLayer(STRUCTPOINTSERV, { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); RecPolygon = new esri.layers.FeatureLayer(RECPOLYSERV, { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); map.addLayers([StructurePoints,RecPolygon]); } function closeEditor(){ if(editIsOn){ dojo.disconnect(editLayersAdded); map.removeLayer(StructurePoints); map.removeLayer(RecPolygon); myEditor.destroy(); } } function addEditor(r){ var contentHolder = "<div id='editorDiv'></div><div id='tmpDiv'></div>"; $j('##editDiv').append(contentHolder); var templateLayers = dojo.map(r,function(result){ return result.layer; }); var widget = new esri.dijit.editing.TemplatePicker({ featureLayers: templateLayers, grouping: true, rows: 'auto', columns: 3 },'tmpDiv'); widget.startup(); var layers = dojo.map(r, function(result) { return {featureLayer:result.layer}; }); var settings = { map: map, templatePicker: widget, geometryService: new esri.tasks.GeometryService(GEOSERVICE), layerInfos:layers, toolbarVisible: true, createOptions: { polylineDrawTools:[ esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYLINE], polygonDrawTools: [ esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYGON, esri.dijit.editing.Editor.CREATE_TOOL_CIRCLE, esri.dijit.editing.Editor.CREATE_TOOL_TRIANGLE, esri.dijit.editing.Editor.CREATE_TOOL_RECTANGLE ] }, toolbarOptions: { reshapeVisible: true } }; var params = {settings: settings}; myEditor = new esri.dijit.editing.Editor(params,'editorDiv'); myEditor.startup(); }
var contentHolder = "<div id='templateDiv'></div><div id='editorDiv'></div>"; dojo.place(contentHolder, "LogOccurrence", "first");
I had experienced the same problem. From what I can tell in testing, the solution is to called <yourEditorWidget>.destroy() successfully. In addition, create the template and editor divs dynamically in the DOM using the tools of your choice. In dojo...var contentHolder = "<div id='templateDiv'></div><div id='editorDiv'></div>"; dojo.place(contentHolder, "LogOccurrence", "first");Include this code prior to or during your creation of the editor-related objects. To deactivate editing or recreate the editing stuff upon opening a container, for example, just call <yourEditorWidget>.destroy();Using static divs in the page prevented the editor from reappearing after a destroy. I could see the editor initially but not after destroy. I believe the destroy operation blows away the domNodes associated with the static divs.
dijit.registry.forEach(function(w){ w.destroy(); });
When I call destroy() and recreate after, got following error:Unable to draw graphic (geometry:null, symbol:null): Tried to register widget with id==templateDiv but that id is already registered.
Hey. After selecting Map from Editor I get the following error when I want to editorwidget.destroy()error message: _E.DISCONNECT IS NOT A FUNCTION
