<?xml version="1.0" ?> <configuration> <title>Northern Data Atlas</title> <subtitle></subtitle> <logo>assets/images/logo.png</logo> <style> <colors>0xCEE7F4,0x39628C,0x355D89,0x294867,0xCEE7F4</colors> <alpha>0.7</alpha> </style> <geometryservice url="http://xyz/arcgis/services/Geometry/GeometryServer" /> <!-- UI elements --> <widget right="15" top="50" config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/> <widget right="-2" bottom="-2" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/> <widget left="0" top="0" config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/> <widget left="10" bottom="2" config="widgets/Coordinate/CoordinateWidget.xml" url="widgets/Coordinate/CoordinateWidget.swf"/> <widget left="-25" top="60" config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/> <map scalebarvisible="true" wraparound180="true" initialextent="-2830000 320000 2510000 5300000" fullextent="-2830000 320000 2510000 5300000" top="40" > <basemaps> <layer label="Modis 250m Land Cover" type="dynamic" visible="true" alpha="1.0" url="http://xyz/ArcGIS/rest/services/landcover/modis250m_mxd/MapServer"/> </basemaps> <operationallayers> </operationallayers> </map> <!-- THIS CONTAINER HOLDS LEGEND ONLY (ON LEFT SIDE) --> <widgetcontainer layout="float" top="45" left="2"> <widget label="Layer Manager" left="5" top="45" preload="open" icon="assets/images/i_layers.png" config="widgets/MyLegend/MyLegend.xml" url="widgets/MyLegend/MyLegend.swf"/> </widgetcontainer> <!-- THIS CONTAINER HOLDS ALL OTHER WIDGETS (ON BOTTOM) --> <widgetcontainer layout="horizontal" bottom="5" left="420"> <!-- MAP CONTROLS --> <widgetgroup label="Map" icon="assets/images/i_globe.png"> <widget label="Bookmark" preload="close" icon="assets/images/i_bookmark.png" config="widgets/Bookmark/BookmarkWidget.xml" url="widgets/Bookmark/BookmarkWidget.swf"/> <widget label = "Swipe / Spotlight" preload="close" icon="assets/images/i_swipe.png" url="widgets/SwipeSpotlight/SwipeSpotlightWidget.swf" /> </widgetgroup> <!-- MAP TOOLS --> <widgetgroup label="Tools" icon="assets/images/GeoprocessingTool48.png"> <widget label="Draw / Measure" icon="assets/images/i_measure.png" config="widgets/eDraw/DrawWidget.xml" url="widgets/eDraw/DrawWidget.swf"/> <widget label="Find" icon="assets/images/i_zoomfull.png" url="widgets/MyFind/MyFindWidget.swf"/> <widget label="Query" icon="assets/images/i_pin3.png" config="widgets/Selection/SelectionWidget.xml" url="widgets/Selection/SelectionWidget.swf"/> <widget label="Edit Features" icon="assets/images/i_edit.png" config="widgets/Edit/EditWidget.xml" url="widgets/Edit/EditWidget.swf"/> <widget label="Time Slider" icon="assets/images/i_clock.png" config="widgets/eTime/eTimeWidget.xml" url="widgets/eTime/eTimeWidget.swf"/> <widget label="Proximity" icon="assets/images/i_pin2.png" config="widgets/MyProximity/MyProximityWidget.xml" url="widgets/MyProximity/MyProximityWidget.swf"/> </widgetgroup> <!-- MAP UTILITIES --> <widgetgroup label="Utilities" icon="assets/images/i_options.png"> <widget label="Print" icon="assets/images/i_print.png" config="widgets/Print/PrintWidget.xml" url="widgets/Print/PrintWidget.swf"/> <!-- only dynamic / tiles map services supported --> <widget label="Export Shapefile" icon="widgets/Export2Shp/assets/images/i_exportToShp.png" config="widgets/Export2Shp/Export2ShpWidget.xml" url="widgets/Export2Shp/Export2ShpWidget.swf"/> <widget label="Screenshot" icon="assets/images/i_camera.png" config="widgets/Snapshot/SnapshotWidget.xml" url="widgets/Snapshot/SnapshotWidget.swf"/> <widget label="Export Map" icon="lu_assets/images/adv_print.jpg" url="lu/etat/pch/gis/widgets/pchPrintWidget/PchPrintWidget.swf" config="lu/etat/pch/gis/widgets/pchPrintWidget/PchPrintWidget.xml" /> </widgetgroup> </widgetcontainer> </configuration>
<?xml version="1.0" ?> <configuration> <geometryservice>http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer</geometryservice> <spatialref>102003</spatialref> <distanceunits> <distanceunit abbr="m" conversion="1">Meters</distanceunit> <distanceunit abbr="km" conversion=".001">Kilometers</distanceunit> <distanceunit abbr="ft" conversion="3.2808">Feet</distanceunit> <distanceunit abbr="mi" conversion="0.000621">Miles</distanceunit> </distanceunits> <areaunits> <areaunit abbr="sq m" conversion="1">Square Meters</areaunit> <areaunit abbr="sq km" conversion="0.000001">Square Kilometers</areaunit> <areaunit abbr="sq ft" conversion="10.763910417">Square Feet</areaunit> <areaunit abbr="sq mi" conversion="0.0000003861021">Square Miles</areaunit> <areaunit abbr="ac" conversion="0.00024710538147">Acres</areaunit> <areaunit abbr="ha" conversion="0.0001">Hectares</areaunit> </areaunits> <pointunits> <pointunit abbr="spal" wkid="102629">NAD83 AL East(SP Feet)</pointunit> <pointunit abbr="wgs84dd" wkid="4326">Decimal Degrees (WGS84)</pointunit> <pointunit abbr="wgs84dms" wkid="4326">DMS (WGS84)</pointunit> <pointunit abbr="utm19n" wkid="2960">NAD 1983 UTM 19N</pointunit> </pointunits> <numericlabelprecision>2</numericlabelprecision> <labels> <textrotationlabel>Rotation</textrotationlabel> <markerrotationlabel>Angle</markerrotationlabel> <pointunitslabel>Point Units:</pointunitslabel> <savelabel>Save Graphics Layer</savelabel> <openlabel>Open Saved Graphics Layer</openlabel> </labels> </configuration>
<spatialref>26913</spatialref>
<?xml version="1.0" ?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Copyright © 2008 - 2009 ESRI // // All rights reserved under the copyright laws of the United States. // You may freely redistribute and use this software, with or // without modification, provided you include the original copyright // and use restrictions. See use restrictions in the file: // <install location>/FlexViewer/License.txt // //////////////////////////////////////////////////////////////////////////////// --> <configuration> <geometryservice>http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer</geometryservice> <spatialref>102003</spatialref> <distanceunits> <distanceunit abbr="m" conversion="1">Meters</distanceunit> <distanceunit abbr="km" conversion=".001">Kilometers</distanceunit> <distanceunit abbr="ft" conversion="3.2808">Feet</distanceunit> <distanceunit abbr="mi" conversion="0.000621">Miles</distanceunit> </distanceunits> <areaunits> <areaunit abbr="sq m" conversion="1">Square Meters</areaunit> <areaunit abbr="sq km" conversion="0.000001">Square Kilometers</areaunit> <areaunit abbr="sq ft" conversion="10.763910417">Square Feet</areaunit> <areaunit abbr="sq mi" conversion="0.0000003861021">Square Miles</areaunit> <areaunit abbr="ac" conversion="0.00024710538147">Acres</areaunit> <areaunit abbr="ha" conversion="0.0001">Hectares</areaunit> </areaunits> </configuration>
