I wrote the code below to list datasets and associated feature classes and shape types (point, polygon, etc.) in an sde. This works fine until I get to the last dataset, Zoning, which contains one feature class and one topology. There, it errors out with "RuntimeError: DescribeData: Method feature type does not exist". Also errors on shapeType if I don't check featureType first.Guessing this has something to do with desc not liking the topology, but is there a way around this other than catching the exception and then continue? Thanks.def getLists(): dsList = arcpy.ListDatasets("*") for ds in dsList: dsName = ds.split(".") print dsName[2].upper() print " - Feature Classes" fcList = arcpy.ListFeatureClasses("*", "", ds) if len(fcList) == 0: print "\t - " + "No feature class in this dataset. \n" continue for fc in fcList: desc = arcpy.Describe(fc) if desc.featureType == "Simple": fcName = fc.split(".") desc = arcpy.Describe(fc) print "\t - " + fcName[2] + ": " + desc.shapeType print "\n"
