In CityEngine 2014.0, there is text.cga in General folder in Esri.lib.
However, when I open it, there are some error in the rule file.
How can I fixt it and how to use the rule?
I've moved your post into the CityEngine space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see moreon the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
When I have trouble with opening a Rule file in CityEngine, I switch to Notepad++ to open it and see if there is something in the rule that is inconsistent. However, if that does not work it might be best to start from scratch.
Not exactly sure what the issue is - if its a bad file, I'd try creating a new workspace - the ESRI.lib gets added by default to every one you create.
You should note that the rule file is referencing textures - images of each letter - and they are located in the assets->General->Text folder so if you are seeing the default UV image (uvtest.png) than this is your error.
Hi David,
Thank you for the reply! Well, the rule file is contained in the rule folder by default. I think it's a sample rule. but, it seems there is no instruction for it. So I wondered how people use the rule file to their project. Can't you see any error when you open the file?
Hi Devin,
When I open the text.cga file, there are so many errors on it, but I can't find the problem.. I also don't know how to use the rule to my project. I just don't know what is the text.cga file for....
Can you tell me the number of your build, as seen with red arrow in image below? Also can you post your version of the Text.cga file. Just so I can see if I get the same compiler errors that you are.
Hi Chris,
Here I attached the rules and assets folders. The build number is the same as yours; 2014.0 140522R. I hope this helps.
