I have a point FC in a mxd file in WGS_1984_Web_Mercator_Auxiliary_Sphere, and displays in Decimal Degrees (Long/Lat). I published it as a mapservice, and retrieved the features in my SOE project. However, the features' Extent are not in Long/Lat. Then, I used the piece of code below to convert the X/Y from GCS to PCS (in meters) but it does not work. What's wrong in my code? Thanks if you can help.
| public IPoint CoordinateConvert(IPoint point, string[] srID) { |
| ISpatialReferenceFactory srFactory = new SpatialReferenceEnvironmentClass(); |
| ISpatialReference srTo; |
| IProjectedCoordinateSystem pcs = srFactory.CreateProjectedCoordinateSystem(Convert.ToInt32(srID[0])); |
| srTo = pcs; |
| IGeometry geometry; |
| geometry = point; |
| geometry.SpatialReference = point.SpatialReference; |
| geometry.Project(srTo); |
| point = geometry as IPoint; |
| double x, y; |
| point.QueryCoords(out x, out y); |
| System.Diagnostics.Debug.Print("X: " + x.ToString()); |
| System.Diagnostics.Debug.Print("Y: " + y.ToString()); |
| return point; |
