I am developing an application with ArcGIS Runtime SDK for .Net and following the MVVM Pattern, in my ViewModel I have an ObservableCollection of GraphicsOverlay that I have binded to the MapView in my View, now when I add a new GraphicsOverlay to the ObservableCollection and add Graphics in it, graphics are not reflection in the View,
I have implemented INotifyPropertyChanged and all other things are working fine with the ViewModel
public class MapViewModel : BaseViewModel
private Map map;
public Map Map
get { return this.map; }
set { this.map = value; }
public ObservableCollection<GraphicsOverlay> GraphicsOverlays { get; set; }
public MapViewModel()
GraphicsOverlays = new ObservableCollection<GraphicsOverlay>();
And in my Method that is called by any event
public void UpdateMarker(MapPoint point)
GraphicsOverlays[0].Graphics.Clear();
// Create a symbol to symbolize the point
SimpleMarkerSymbol symbol = new SimpleMarkerSymbol(SimpleMarkerSymbolStyle.X, System.Drawing.Color.Yellow, 20);
// Create the graphic
Graphic symbolGraphic = new Graphic(point, symbol);
// Add the graphic to the graphics overlay
var newGraphicsOverlay=new GraphicsOverlay();
GraphicsOverlays[0].Graphics.Add(symbolGraphic);
And in my View I have
<esri:MapView x:Name="MyMapView" Grid.Column="0" DataContext="{StaticResource MapVM}" GraphicsOverlays="{Binding GraphicsOverlays}" Map="{Binding Map}" Cursor="{Binding MapViewCursor}">
I am unable to find any sample that does exactly this, so how to do this, I am new to arcGIS, Thanks in advance.
