//Listener event for feature selection and the popup info widow dojo.connect(theUsgsLayer,"onClick",function(evt){ //Listener event for feature selection and the popup info widow var query = new esri.tasks.Query(); query.geometry = pointToExtent(map,evt.mapPoint,15); var deferred = theUsgsLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW); map.infoWindow.resize(350,300); map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); }); //Listener event for feature selection and the popup info widow dojo.connect(theFloodplainLayer,"onClick",function(evt){ //Listener event for feature selection and the popup info widow var query = new esri.tasks.Query(); query.geometry = pointToExtent(map,evt.mapPoint,15); var deferred = theFloodplainLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW); //map.infoWindow.resize(map.width * 0.70, map.height * 0.6); map.infoWindow.resize(200,175); map.infoWindow.setFeatures([evt.graphic]); map.infoWindow.show(evt.mapPoint); });
function pointToExtent(map, point, toleranceInPixel) { //Function to convert a point coordinate into a rectangle area var pixelWidth = map.extent.getWidth() / map.width; var toleraceInMapCoords = toleranceInPixel * pixelWidth; toleraceInMapCoords = 1320; return new esri.geometry.Extent( point.x - toleraceInMapCoords, point.y - toleraceInMapCoords, point.x + toleraceInMapCoords, point.y + toleraceInMapCoords, map.spatialReference ); }
dojo.require("esri.layers.FeatureLayer");
var layerObj = new esri.layers.GraphicsLayer({id:"points_glayer", visible:true, opacity:1}); map.addLayer(layerObj); var glayer = map.getLayer("points_glayer");
