Dim m_disp As MapDisplay = ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay 'Define the connection properties Dim connProps As ServiceConnectionProperties = New ServiceConnectionProperties(ServiceType.Ims, New Uri("http://nowcoast.noaa.gov"), "nowcoast") 'Create a new ServiceLayer Dim svcLayer As ServiceLayer = New ServiceLayer(connProps) 'Name Layer svcLayer.Name = "Hurricane Track" 'Connect to Service Dim connected As Boolean = svcLayer.Connect() 'Array list of layers to connect to Dim LayerList As New ArrayList() LayerList.Add("Tornado Warnings") LayerList.Add("Flood Warnings") LayerList.Add("Flash Flood Warnings") LayerList.Add("Severe Thunderstorm Warnings") LayerList.Add("Extreme Wind Warnings") 'Check to see whether the connection was successful and add layers from Array List If (connected) Then For Each NOAALayer As String In LayerList For Each lyr As ServiceChildLayer In svcLayer.ChildItems If lyr.Name = NOAALayer Then lyr.Visible = True m_disp.Map.ChildItems.Add(lyr) Else lyr.Visible = False End If Next Next Else 'Investigate connection issue. Dim status As ConnectionStatus = svcLayer.ConnectionStatus MsgBox("Server Connection Failed!" & status.ErrorString) If status.HasError Then System.Diagnostics.Debug.Print(status.ErrorString) End If End If End Sub
Dim theMapItem As MapItem Dim m_disp As MapDisplay = ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay 'Define the connection properties Dim connProps As ServiceConnectionProperties = New ServiceConnectionProperties(ServiceType.Ims, New Uri("http://nowcoast.noaa.gov"), "nowcoast") 'Create a new ServiceLayer Dim svcLayer As ServiceLayer = New ServiceLayer(connProps) 'Name Layer svcLayer.Name = "Hurricane Track" 'Connect to Service Dim connected As Boolean = svcLayer.Connect() 'Add the layer to the map. 'Check to see whether the connection was successful If (connected) Then 'Add the layer to the map. theMapItem = svcLayer.FindByName("Tropical Cyclone Track Lines") If Not (theMapItem Is Nothing) Then theMapItem.RemoveFromParent() theMapItem = Nothing End If m_disp.Map.ChildItems.Add(svcLayer) Else 'Investigate connection issue. MsgBox("Server Connection Failed!") Dim status As ConnectionStatus = svcLayer.ConnectionStatus If status.HasError Then System.Diagnostics.Debug.Print(status.ErrorString) End If End If
