def AddZero(field): new = field[:4] + "0" + field[4:] return new;
AddZero( !your_fieldname! )
Try this in the field calculator, be sure to set the parser to Python:Pre-logic code block def AddZero(field): new = field[:4] + "0" + field[4:] return new; And use this as the expression: AddZero( !your_fieldname! ) [ATTACH=CONFIG]24010[/ATTACH]
def AddZero(field): # add after 4th char if len == 7 if len(field) == 7: new = field[:4] + "0" + field[4:] # here is the "then" statement elif len(field) == 9: new = field[:5] + "0" + field[5:] # inserts 0 @ 'xxxxx0xxxx' (after fifth position) return new;
You can add an if/then condition very easily with a length test. What kind of conditions were you thinking of adding?Here is an example of changing where to add the 0: def AddZero(field): # add after 4th char if len == 7 if len(field) == 7: new = field[:4] + "0" + field[4:] # here is the "then" statement elif len(field) == 9: new = field[:5] + "0" + field[5:] # inserts 0 @ 'xxxxx0xxxx' (after fifth position) return new;
def AddPunc(field): new=field[0:2] new+="-"+field[2:4] new+="-"+field[4:6] new+="-"+field[6:9] new+="-"+field[9:12] new+="-"+field[12:15] return new
from itertools import * def formatPID(in_pid, delimiter='-', groups=()): # groups are how you want to break it up in_pid = str(in_pid) it = iter(in_pid) return delimiter.join(''.join(islice(it, i)) for i in groups)
formatPID(!Your_PID_Field!, '-', (2,2,2,3,3,3))
def AddPunc(field): new=field[0:2] new+="-"+field[2:4] new+="-"+field[4:6] new+="-"+field[6:9] new+="-"+field[9:12] new+="."+field[12:15] new+="-"+field[15:18] return new
