How is the height unit (e.g. m, cm, ft, etc.) specified within the Classify LAS By Height tool?
Thanks.
Tony
Yes...the Classify LAS By Height tool. I've created a LAS dataset from UAV processed aerial imagery (Pix4D). I've classified the ground (using Classify LAS Ground) and would now like to use the Classify LAS By Height tool to classify vegetation (regenerating trees) as low, medium or high vegetation (LAS codes 3,4 and 5). However, it's unclear to me what units the height_from_ground values in the Classify LAS By Height tool uses.
Classify LAS By Height—Help | Documentation
can you elaborate? is this the tool you are referring to? or another one from the toolset?
Change LAS Class Codes—Help | Documentation
