I am using a custom style set to symbolize point features that references a custom font file (.ttf), which is installed on my PC.
Everything displays properly in Arc Map 10.5.1, but inside ArcGIS Pro 2.1.1 the same font file is not available when I import the custom style set and apply the symbology or import an existing mxd into ArcGIS Pro. The style set applies default characters as if the font file is not installed.
A) Does ArcGIS Pro reference all fonts installed on you PC in the same manner as Arc Map?
Are custom font files not permitted in ArcGIS Pro?
