Is there a way to restrict editing field by field in a AGO web map?
I planned to just uncheck the Edit checkbox in the popup of the webmap but found a user can just go in and check it back on, then edit all they want.
I can not limit the field using a View because I still want the user to see the field. (It would be awesome if the Define field box had 2 checkboxes, View and Edit, like the popup does.)
I think the answer is no since field level has always been an issue but wanted to check.
thanks
