I removed GraphicsLayer.MouseEnter and updated the graphic on a button click event my map tip still shows the new value. Please try the attached sample. private void Button_Click(object sender, System.Windows.RoutedEventArgs e) { GraphicsLayer layer = this.MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer; var graphic = layer.Graphics.FirstOrDefault(g => (int)g.Attributes["ObjectID"] == 24); if (graphic != null) { var oldVal = (int)graphic.Attributes["MyAttribute"]; System.Diagnostics.Debug.WriteLine(oldVal); graphic.Attributes["MyAttribute"] = oldVal + 1; } } If you can tweak this sample and let me know the steps to reproduce the issue you are seeing with Maptip, that would be great.
Can you share with us your code? The MapTip displays values from graphic attributes, even when these graphics come as a result of a Query. I am using the following SDK sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#GraphicsMapTip with the following code-change.In this sample, I have 2 attributes that I display in my MapTip. One is from the service and the other is a made up attribute that I modify in my code. You can see in the Output window its previous value and in the Maptip its new value. I see that the map tip is updated. If you have some code to share or steps to reproduce, that will be great. <Grid.Resources> <esri:SimpleRenderer x:Key="MyRenderer"> <esri:SimpleRenderer.Symbol> <esri:SimpleFillSymbol Fill="Red"/> </esri:SimpleRenderer.Symbol> </esri:SimpleRenderer> </Grid.Resources> <esri:GraphicsLayer ID="MyGraphicsLayer" Renderer="{StaticResource MyRenderer}" MouseEnter="GraphicsLayer_MouseEnter"> <esri:GraphicsLayer.MapTip> <StackPanel> <TextBlock Text="{Binding [MyAttribute]}"/> <TextBlock Text="{Binding [HOUSEHOLDS]}"/> </StackPanel> </esri:GraphicsLayer.MapTip> </esri:GraphicsLayer> void StatesGraphicsLayerQueryTask_ExecuteCompleted(object sender, QueryEventArgs e) { GraphicsLayer layer = this.MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer; foreach (var g in e.FeatureSet.Features) { Random r = new Random(); g.Attributes["MyAttribute"] = r.Next(0, 10); layer.Graphics.Add(g); } } private void GraphicsLayer_MouseEnter(object sender, GraphicMouseEventArgs e) { var oldVal = (int)e.Graphic.Attributes["MyAttribute"]; System.Diagnostics.Debug.WriteLine(oldVal); e.Graphic.Attributes["MyAttribute"] = oldVal + 1; }
I wish I could share the code...Anyway, the difference between your sample and mine is that I do not implement GraphicsLayer_MouseEnter event handler. I did a DictionaryConverter and bind maptip value to a graphic attribute (like you did). Am I supposed to implement the mouserEnter event handler in addition to MapTip???
I cannot replicate the issue with the following code:In this sample, I update the number of households and print in the OutputWindow its old value so I can compare the result displayed in my map tip. <esri:FeatureLayer ID="MyStateLayer" Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5" OutFields="*" MouseEnter="FeatureLayer_MouseEnter"> <esri:FeatureLayer.MapTip> <TextBlock Text="{Binding [HOUSEHOLDS]}"/> </esri:FeatureLayer.MapTip> </esri:FeatureLayer> private void FeatureLayer_MouseEnter(object sender, GraphicMouseEventArgs e) { var oldVal = (int)e.Graphic.Attributes["HOUSEHOLDS"]; System.Diagnostics.Debug.WriteLine(oldVal); e.Graphic.Attributes["HOUSEHOLDS"] = oldVal + 1; }
