I am under the impression that when feature linked annotation is created for a feature class that after an attribute that was included in the original label expression is changed / updated that the annotation and its associated label would be updated to reflect the attribute change. Am I wrong in assuming this? From the help documentation it states that it should.
I am using Desktop 10.4.1 with an ArcEditor license with a feature class in a file geodatabase. I created a label expression using python as the parser that uses 3 fields to build a stacked label with some conditional formatting. I've been right-clicking the feature class and storing the annotation in a database for all features and made sure that feature linked is checked.
If I go into the original feature class that the annotation was created from and edit one of the fields associated with the label expression I don't see the text updating in the annotation class TextString field or the label itself.
Is there a setting that may be preventing the update? I came across a few threads mentioning that SQL queries could be causing an issue. I haven't used any or a definition query on any of the layers. I've tried it with a new feature class with a single point feature and 3 attributes and still haven't seen it update.
Any help is appreciated
